Thread: Options for grading with AJA/BMD/Matrox
Results 1 to 3 of 3
  1. #1 Options for grading with AJA/BMD/Matrox
    Feb 2010
    Croatia
    Recently I got some offers from several local resellers for setting up a system that we could grade on. I told them we're working with RED, in 25p, finishing for 2k, HD and SD and would like to get the accurate-as-possible 10bit picture on Panasonic 12 series plasma screen from FCP, Color and After Effects. So, long story short I got 3 options back: Kona 3, BMD Multibridge Eclipse and Matrox MXO2. I read a lot of stuff here about similar set-ups and as far as I understand Kona3 is the best option, right? BMD is cool but it relies on CPU if I'm not mistaken, and although MXO2 can output 10bit the signal in it comes from DVI which is 8bit so it's not 10bit in the end?
    Can you please tell me if it's possible to achieve all that with Kona3 and if it's the best way. Will we need some sort of converter from Kona3 to plasma? Would it be smart to invest in Ultrascope or similar tool for checking and adjusting the signal?
    Thanks!
    Feb 2010
    Croatia
    Actually MXO2 doesn't connect to DVI so I made a mistake in earlier post. So all three of them can give 10bit out. Now what?
    EDIT: Just recieved an email from AJA reseller saying that Kona3 doesn't support 2k in 25p :( I guess it's the same problem that Paul Belanger has according to this thread: http://www.reduser.net/forum/showthr...ighlight=kona3
    On the CreativeCow I read that all you have to do is create your own preset for 2k 25p by changing settings in the 24p preset, also someone here mentioned that they're working with 25p so it's a little bit confusing... Does anyone knows from practice if it's possible to do 2k 25p with Kona3? Thanks!
    Feb 2010
    Croatia
    Please, anyone?
Tags for this Thread
View Tag Cloud
