Color Science?
Same?
Color Science?
Same?
These are very impressive results- I wonder what the new contamination level is? Although once you get past 1.2 color shifts really start to become more of a problem ...
Thanks again for providing us with the test results. :)
I don't understand. With a hot mirror held over the top 1/4 of the frame why is the jacket still white-pink? And the original color is green, right?
We probably shouldn't have even put the IR filter in at all. It complicates the comparison of the two sensors.
The top part of the Mysterium sensor (that is filtered) looks like the IR is pretty much gone - the soft filter edge makes the distinguishing line a little blurred - but if you put your hand over the bottom part of the Mysterium image and only look at the top part - which is getting filtered - the blacks start to look a little more neutral.
In the MX sensor - the line between filtered and unfiltered is invisible. The IR filter isn't doing anything. It doesn't need to.
The lamp was spotted in as well - so there is a bit of a vignette. Not ideal - but just look at the overall difference in the two sensors.
MX rules!
