Click here to go to the first RED TEAM post in this thread.   Thread: M-X Reel
Page 11 of 24 FirstFirst ... 78910111213141521 ... LastLast
Results 101 to 110 of 235
  1. #101
    Aug 2008
    Quote Originally Posted by Michael Cioni View Post
    Finally, with the new color management between RedColor and RedGamma, the color separation during offline was much more pleasant to work with than I'm used to with RedSpace. This also improved the offline process a great deal. What's even more impressive is this even improved the DI process because for the first time in DI (for us at least) we were able to work in the same color space in grading as we were in offline. Because I don't recommend RedSpaceRedSpace as a DI starting point, dailies and DI rarely saw the same images. With RedColorRedGamma, we are now speaking the same language, which again, translates to a powerful, seamless handshake between offline and DI.
    Hey Michael,
    Thanks for the update. Can you speak about your process for the cut/DI? Did you use RC-X to color this or do you have the new colorspace working in Pablo?
    Best,
    T
    Senior Member christopher witzke's Avatar
    Mar 2009
    Louisville/Cincinnati/Nashville/Indy
    Thank you Michael!.... the stills are superb!
  3. #103 ?????
    Senior Member Jacek Zakowicz's Avatar
    Jun 2008
    Hello All -
    It was the only digital cinema experience I've looked through a viewfinder and seen more latitude coming off the sensor than I did the naked eye.
    4K Stills:
    http://www.lightirondigital.com/Ligh..._4K_STLLS.html
    Aren't we getting ahead of ourselves here a bit?
    If you cant see it with the naked eye- you can't see it viewfinder or not....
    Jacek Zakowicz, Optitek-dot-org, jacek2@optitek.org
    Professional Broadcast and Digital Cinema Equipment
    Jul 2009
    San Clemente, CA
    Quote Originally Posted by alex lemon View Post
    yes, would be great to get some low-light shots with the 2/3 sensor!
    been wondering the same thing for a while now(2/3" low light performance) and to my knowledge red hasn't commented on this despite the question coming up multiple times in other threads.
    great to see the 18mm rpp shots, hope the 6mm mini prime looks that good!
    It's4k here but I'm not sure those stills got a full debayer. I'm seeing above average bayer artifacting, or maybe I'm just doing an above average amount of grading. :)
    Jan 2007
    Looks like it is working now. Full files, 49.2MB each.
    BTW, could we know the T-Stop used on the 18mm for the aerials?
    Writer - Director
    Crowing Lakes.com
    Junior Member
    Mar 2009
    My wet spot just got bigger...
  8. #108 DI Process
    Senior Member Michael Cioni's Avatar
    Mar 2008
    6381 DeLongpre | LA | CA | 90028
    Quote Originally Posted by Todd M. View Post
    Hey Michael,
    Best,
    T
    Todd,
    The dailies were processed in RCX. For the DI, the files were imported into Pablo, which does support the MX footage natively. So we used our normal Pablo auto-conform for 4K debayering and conforming of XML exports from FCP. Grading was done with 4K files at fullres/high and we did not use any noise reduction-Pablo or otherwise. So what you see on the projection is what the sensor saw.
    I should clarify with my comment to sensitivity:
    With the lens wide-open, the images on the monitor and EVF were brighter than the room was to the eye. Similar to how things look on 1/3" chips cameras like the PD170.
    As for grading, Gavin- these images are pre-processed with gamma correction - so they no longer hold the dynamic range of the source R3Ds by any means. Using these files to evaluate in grading is not a good idea and will not show you the results that you get from the RAW files where they came from. These images are a full debayer and can show how clean the noise floor is demonstrate that there is no aliasing in the shirt or the car. that is the only intent I have in sharing these images.
    Make sense?
    m
    Michael Cioni
    Senior Vice President of Innovation,
    Panavision & Light Iron
    Twitter @michael_cioni
    Instagram @ michaelcioni
    Blog @ michaelcioni.tumblr.com
    www.lightiron.com
    www.dxl.panavision.com
    Quote Originally Posted by Rob Ruffo View Post
    Yet people still buy F35s!? I don't get it.
    Heh, not for much longer....
    I would love to have that sensor in just a still camera....
    Hmmmm.....RED could clean up just selling still cameras...
    Imagine a still camera that could convert and accept RED, PL, Nikon or Canon
    lenses....
    Jan 2007
    Sorry Todd. So do the tiffs not show the dull dynamic range?
    BTW, HOLY SMOKES... that shirt looks CLEAN! Though with so much detail it actually looks like it needs a wash with a touch of bleach. ;P
    What blows me away is how much separation there is between the black beanie close to the light and the white wall in the BG.
    (Below are 8-bit 1:1 .JPGs, untouched)
    Writer - Director
    Crowing Lakes.com
