Click here to go to the first RED TEAM post in this thread.   Thread: November 30th Announcement Feedback
Closed Thread
Page 58 of 144 FirstFirst ... 84854555657585960616268108 ... LastLast
Results 571 to 580 of 1434
  1. #571
    Sep 2009
    Toronto
    Quote Originally Posted by Jarred Land View Post
    Touch to lock focus... if she has a face, you can use face tracking, or if not you can use the traditional focus points.
    I'm new to the whole autofocus thing and its different modes, so forgive any ignorance.
    I do a lot of hand held run and gun manual focus so the thought of touching a screen with my left hand in the middle of shooting to lock focus strikes me as often impractically disruptive, as does the notion of face tracking ( subject spontaneously turns away, focus goes poof ). I may be wrong but both of these methods would seem less accurate in a run and gun situation than controlling an X cursor on the LCD/viewfinder with a pressure sensitive joystick/rocker on the side handle under my right thumb...which also would work in the VF as opposed to just on the LCD and be more accurate for very narrow DOF focus than any one of my fingers touching a 2.8'' or 5'' lcd.
    Maybe this idea is already part of the side handle system?
    Documentary Filmmaker
    AllinOneFilms.com
  2. #572
    correcto... and you can use those rings on the normal REDMOTE, Side Handle or the REDMOTE PRO to handle either of the rings (Z,I,F) as well.
    so please excuse my ignorance on this but does that mean no manual focus what so ever on the fixed?
    story, story, story, and lots of hard work.
  3. #573
    Quote Originally Posted by jay mannark View Post
    You can change it manually via one of the Rings you assign the focus to...
  4. #574
    Senior Member Peter Moretti's Avatar
    Apr 2008
    Quote Originally Posted by GPSchnyder View Post
    Can you manually focus and zoom at the same time?
    Can you zoom and autofocus at the same time?
    Thanks much.
    1110001100010102
  5. #575
    We appreciate how much time you guys spend here too.. We are all in this together :)
    what a great attitude love it
  6. #576
    Member Neil B Smith's Avatar
    Nov 2008
    Suffolk, United Kingdom
    Can anyone at RED answer...
    Can I upgrade the LCD on the 2/3" Fixed Lens Scarlet from the 2.5" to a more comfortable 5" touchscreen LCD?
    Also is there any news or specs to what SSD's we can expect to be using. I know 1.8" SSD's. Are RED going to issue their own? and what are the specs going to be? Most 1.8" SSD drives seem to be ablout 80MB/s write speed and 200-250MB/s sustained is this sufficient for the Scarlet's Redcode 100 codec?
    Neil B Smith
    NBS Studio
    HD, 2K, 3K, 4K video production & 3d animation
    Company website: www.nbs-studio.com/videoproductioncompany.php
    Video Domain Name Rental: www.domains4renting.com
  7. #577
    Senior Member Jon Howe's Avatar
    Jan 2007
    Utah
    Quote Originally Posted by Stuart English View Post
    ...the 3-axis accelerometer data is captured each frame, so we can extract the camera's 3D orientation from that, and
    this is complemented by the GPS data which acts as a time / location reference.
    So does this mean that I can export camera movement data to Cinema 4D, AE, Maya, Motion, etc?
  8. #578
    Apr 2008
    Quote Originally Posted by Clayton Burkhart View Post
    ... The real questions: How fast will the Scarlet S35 or FF be reading off the sensor, in order to get around rolling shutter? How will it be downscaling to avoid aliasing, moire, artifacts, etc.? These are the solutions that are worth paying for.
    Sorry, but I don't see how this is the "real question" at all. It's like asking Toyota back in the day if their gas tanks will blow-up upon impact. Um they didn't make the Pinto.
    And Red didn't make the 5/7D's. Why would you think they'd start introducing problems that not only don't exist w/ the Red One but have also been mentioned by the Red team as being siginifcant detriments to using the current crop of still cameras for motion work?
    What you brought up simply isn't a problem w/ Red now... and there is no reason to believe it will be in any of their future cameras.
    1110001100010102
  9. #579
    Jun 2009
    Sakes I really hope we make the projected May-June release.
    my fingers will be perpetually crossed.
  10. #580
    Junior Member
    Jun 2009
    Dallas, TX
    Quote Originally Posted by Zachary Flugum View Post
    That is the same question I have. First post here but have been reading for quite some time. These announcements are quite impressive. Looking forward to getting a Scarlet in the near future. This question may just decide which version I will be going with.
    Thanks,
    Flugo
    Depth of field is a function of the size of the image at the image plane. So for any given camera system, DOF is a direct function of the size of the sensor. Larger sensors have inherently more shallow DOF than do smaller sensors.
    You can manipulate DOF in three ways: 1) camera to subject distance, 2) focal length, and 3) aperture. So with a given composition on a 35mm sized sensor, the same COMPOSITION (size of the subject in the frame) with the same camera to subject distance and aperture setting will produce a more shallow DOF on a larger sensor and greater DOF on a smaller sensor. It just so happens that to produce the same composition on a 2/3" (or roughly 16mm sized) sensor requires about half the focal length (or a little less) in lensing than a 35mm sensor does.
    (Of course, one must keep in mind that a 35mm still camera has a larger image area than does a 35mm motion picture camera, so comparisons of lens focal lengths demands clarification as to which "35mm system" you are referencing.)
    Some DPs/Directors find it easier to think the other way around and start with focal length rather than sensor size... which is why people refer to "35mm equivalent" for the 2/3" Scarlett (for example). Ultimately, one should choose the system that serves the shooter's needs best. For many (especially ENG,) having a smaller sensor makes it easier to focus in a run & gun situation because there is inherently greater DOF within the system.
    Probably more info than you need, but since several have asked, I felt compelled to offer it.
    Tim
