Click here to go to the first RED TEAM post in this thread.   Thread: November 30th Announcement Feedback
Closed Thread
Page 121 of 144 FirstFirst ... 2171111117118119120121122123124125131 ... LastLast
Results 1,201 to 1,210 of 1434
  1. #1201
    Jan 2007
    Quote Originally Posted by Jarred Land View Post
    good idea :)
    Are we there yet? :)
    Writer - Director
    Crowing Lakes.com
  2. #1202
    Senior Member Nik Harper's Avatar
    Nov 2009
    Seattle, WA
    My questions already got lost i think so i'll ask one more time just in case it will be seen the second time haha.
    First, is the 1.8" ssd reader essential for uploading clips? Or can you upload without it?
    Second, what is the uploading like? Do you just drag your clips off of the drive onto the computer? Or is there some other process?
    Nik Harper
    Scarlet-X #221
    WWW.LAMARPLUSNIK.COM
    Follow us: @LAMARPLUSNIK
  3. #1203
    Senior Member Justin O'Neill's Avatar
    Jan 2007
    San Diego/LA/Seattle
    Quote Originally Posted by nikharper View Post
    One option is: "Remote camera control and Files can be copied off the media via gigabit ethernet". #7 on the Nov. 30th announcement.
    Jarred clarifying:
    Quote Originally Posted by Stuart English View Post
    To clarify -
    You record to the camera media first, then you can copy that file (or files) over Ethernet.
  4. #1204
    Nov 2009
    Seattle, WA
    Quote Originally Posted by Justin O'Neill View Post
    Jarred clarifying:
    yeah i saw that, and that is pretty tight, i must say. but i was just wondering about the 1.8" methods more specifically, but now that we're talking about it, is the gigE method where you plug an ethernet cable from camera to computer or what?
    Nik Harper
    Scarlet-X #221
  5. #1205
    Jan 2007
    Yeah I imagine you plug one end of an ethernet cable into the brain and one end into your computer and the media mounts as an external drive. Pretty cool.
  6. #1206
    Member Norman B. Miller's Avatar
    Jul 2009
    Costa Mesa, CA.
    Was wondering if the HDR can be used for motion as well as stills on the Scarlet?
  7. #1207
    Senior Member paulherrin's Avatar
    Oct 2008
    Johnson City, TN
    Quote Originally Posted by Norman B. Miller View Post
    we don't know much about the HDR feature on the new cameras as of yet... though we can expect it will be more than the typical auto bracketing on DSLR's.
    now, of course - you could use even that for time-lapse motion. some have speculated there will be HDR video capabilities... I doubt it very much so.
    though, i think with the latitude of the RAWs you could generate HDR from a single clip by essentially "baking out" your footage at say 3 different levels, and using your favorite tone-mapper (I like Photoshop) to generate your images frame by frame (simple automations or batch processing).
    I would love it if someone with One could run some tests.
    (or send me some files and I'll run some)
    pH
  8. #1208
    Quote Originally Posted by Pietro Impagliazzo View Post
    But things are gonna be baked-in in the RGB mode.
    Not necessarily. It'll be more baked but there is nothing to prevent RED from outputting an unprocessed RGB image. Any LUTs applied to the footage would be on top of a flat RGB anyway so you might as well encode it as metadata.
    Gavin Greenwalt || im.thatoneguy
    im.thatoneguy[at]gmail.com | Straightface Studios | VFX & Animation
    Canon Scarlet-X package available to rent in Seattle, WA
  9. #1209
    Member ScottyC's Avatar
    Nov 2008
    Pittsburgh, PA
    Quote Originally Posted by paulherrin View Post
    I doubt the motion idea too. I thought about this a few years ago when I started playing with HDR photo's. I thought it would be cool to capture HDR motion, but there are some levels that technology hasn't reached yet. One is that I don't believe a true HDR monitor exists yet. Though the advancement of LED LCD's and 120Hz capabilities are bringing home theater to a new level, this still isn't a true HDR monitor. Two, the processing of motion HDR would kill your computer. I mean, processing HDR photos can really work out your processors... so quantify that by a large amount of images captured through motion and well, you get the idea. And lastly, the final result is still going to be down-converted to an image with less bit-depth, etc... so HDR motion is like massive overkill, no matter how important the project.
    I am curious about the ethernet data transfer. I heard there were some connectivity issues with this type of connection before. I think I read this when I was researching a DROBO disk storage device. It had the ethernet connection, but people mentioned issues that needed to be worked out with that. ?? IDK, maybe safe to just plan for a SSD reader.
    And given the info about the Canon lenses and capable line/mm resolution... I am starting to lean towards the 8X fixed after a year of wanting the 2/3" cinema with a Canon mount. At least I know what I am getting into before it's too late!
    By over-estimating your problems, you under-estimate your ability to overcome them.
  10. #1210
    For capturing HDR motion, at low frame rates, why couldn't you just not reset after the read and say read three times in a row?
    I don't see why this wouldn't be possible. I think it would be hit or miss for awhile until people understood what kind of settings they would need, but I don't see why it wouldn't be doable. Getting the right lens speed will be important, but it would be pretty cool.
    Essentially, at the minimum, you'd get three frames in a row at different exposures and then reset. Given the scarlet can do 150 frames per second, this should NOT be a hard thing to do in camera. Now, seeing anything ON the camera in HDR is not gonna happen, but in post is where you work the magic like you do with a still.
    Sound pretty cool to me!
    Rick
