Thread: Not getting realtime transcodes on batch export
Page 1 of 2 12 LastLast
Results 1 to 10 of 11
  1. #1 Not getting realtime transcodes on batch export
    Senior Member Michael Totten's Avatar
    Jan 2008
    Los Angeles, CA
    I just installed the rocket recently, so maybe I'm overlooking something obvious here.
    I spent the better part of yesterday grading/transcoding in rocketCine-x... I did three batch exports (anywhere from 50-125 clips at a time).
    Export Presets:
    1920X1080 23.98
    Apple ProRes HQ
    It's hard to say exactly how slow it's going but I would say it's taking roughly twice as long (perhaps more). Could it be that the R3D's files and the export folder are on different external FW800 Drives? I would think those drives could handle this kind of bandwidth and the Mac bus should be ok, no ?
    thanks. Any insight would be appreciated.
    Senior Member Mike Prevette's Avatar
    New York, NY
    Well ProRes and the Quicktime overhead slow it down a bit. The way I understand it RedRocket just does the debayer, then the CPU does any format encoding that needs to happen (alla turn raw rgb info into prores) Try encoding to tiffs or DPX's and It'll be a little bit faster.
    But the real slow down is going to be those firewire 800 drives. On some macs if 2 fw800 drives are on the same bus it divides the bandwidth of the port in half, to basically FW400 speeds. Try writing to an internal drive or RAID.
    _mike
    "One for a meal, One for the reel, or One to learn something"
    Jan 2008
    Los Angeles, CA
    Quote Originally Posted by Mike Prevette View Post
    I may be wrong but I'm pretty sure that Jim mentioned the rocket was doing realtime encode to Apple Pro-ResHQ (can anyone verify this) ?
    Mike I'm going to do a test to a few different drives. I'm sure the FW800 bottleneck on the same bus is part of the equation... but I'm really hoping once I remedy that I can expect realtime encodes to pro-res.
    Senior Member Kaku Ito's Avatar
    Feb 2008
    Chiyoda-ku, tokyo
    Codec like ProRes requires some CPU power to compress, so I'd say it takes little longer than realtime. With fast enough storage then DPX will render realtime, maybe uncompress QT would be not so slow neither.
    Kaku Ito
    rawesome! Equipments
    RED Epic-M, RED Epic-x, RED ONE MX x2, RED ONE Mysterium, Allstar A-mount, Epic Canon Ti Mount, 1.8' SSD modules, RED PRO Prime Set (18 through 100mm), various Nikon and Zeiss Lenses, 17-55mm RED Pro Zoom, 18-85mm RED Pro Zoom, x2 RED ROCKET, Mobile Rocket, DaVinci Resolve, Cubix, GTX-285, Quadro 4000, few Mac Pros, few MacBook Pros, Sony BVM-D24, Panasonic 65 inch Series 12 plasma, Calman with Klein probe.
    Rawesome! One Stop RAW Visual Production Service
    Mar 2008
    New York City
    Guys does anyone have a number of fps encoding ProRes HD aon the latest MacPro?...
    I actually asked several times in severals thread but nobody that have the rocket seems answer...
    so how many FPS encoding ProRes HQ 23.98 on a dual cpu latest macpro???
    if there is no fps speed render info in redcinex ,please try a 3 minute clip and see how it takes...
    Thanks a lot
    g
    Jan 2008
    Los Angeles, CA
    Quote Originally Posted by Gabriele Turchi View Post
    Thanks a lot
    g
    I have the latest 2.26 MacPro with a 4870 ATI graphics card & 16GB RAM. I'll try and do a test later this afternoon. I'm wondering if those Intel X-25 raided solid state drives would speed things up ? anyone have them installed in their system?
    Aug 2007
    Boston
    I can't speak for actual transcode rates, but on the same system, same drives, same files, transcoding to Apple ProRes is about 50% slower than Avid DNxHD when using the REDROCKET. I am sure the efficiency of encode times is a factor relatively speaking. In all cases, the hard drives will be a bottleneck. I am using a 16TB RAID 0.
    Michael
    Ernst Lubitsch
    Mar 2008
    New York City
    Guys if you use 1 drive to read the r3d and 1 drive to write it's enough...
    R3d it's 36MB/sec and prores less than that...
    A normal hard drive sustain 50/MBsec...
    Use a raid it's always suggested but not essential..
    G
    Feb 2009
    San Juan, Puerto Rico
    Would going to ProRes NON-HQ be faster than with HQ? Does resolution make it slower, or the burn-ins? How about including audio?
    I have to start transcoding about 4-6 hours of material per day soon.....
    ________________________________________
    Frank Cueto
    Reaktor Post & Transfer
    Baselight Color Correction and DI, DaVinci Film Transfers (S35,35,S16 & 16) & Tape to Tape
    Smoke Advanced & Smoke HD ON-Line Suites
    (3) GFX/VFX Suites
    (2) Final Cut Pro Suites with HD-SDI Monitoring and IO
    ProTools 5.1 HD Suite, with HD-SDI monitoring/IO,recording booth & FX-Music Libraries
    (2) On-Set workstations powered by RED Rocket™ with 16TB RAID 6 storage & Dual-ESata CFReaders
    Feb 2009
    *BUMP*
    Frank Cueto
    (3) GFX/VFX Suites
