thanks
bumping this thread to keep it high.
David
Bump
Hi all, Merry Christmas and Happy New Year 2010.
I am facing some problems and I would like to request you all to give me your valuable suggestion to solve my problem.
I shot a movie with red 4k camera and my workflow is editing in final cut studio 3 and color correction and color grading in color 1.5( with r3d file which files make in shooting) . Our monitoring on Apple cinema HD 30” , everything was fine but when we are trying to get the output by color to fcp then 2k, HD, DV,CD,DVD and other……the output result comes out be worst which is not useful to telecast and projection in the theather. And when we try to copy on dv tape with fire wire1394 flicker also seen.
I hope you all will suggest me to get the output correctly we are eagerly waiting for your kind and sincere suggestions.
Thanks,
Hi David Battistella,
I am facing some problems and I would like to request you to give me your valuable suggestion to solve my problem.
Thanks,
Thanks David,
Yes, Our output setting in color 1.5 is uncompress 10 bit 4.2.2
Render quality- Full
Grading – full
In color I can’t found codec.
I want to render r3d to Quick Time Movie.
hi,
i have exported an XML from FCP where I edited with ProRes HQ QT's. Imports fine into ClipFinder, but the RED source clips exist on more than one drive, but clipfinder only allows selection of one directory yet the sequence sources clips from several drives. is there a workaround?
I recently ran into a problem round-tripping back to FCP: If the original fcp track had more than 14 audio tracks, it would not return. When I reduced the track count to 14, it made the trip back ok.
Does this sound familiar to anyone? Was it known/in the docs?
I'm curious if it is repeatable on other systems - please report back.
Thanks.
