Thread: Apple color r3d workaround
Page 1 of 7 12345 ... LastLast
Results 1 to 10 of 62
  1. #1 Apple color r3d workaround
    Hi all,
    Wanted to report a solved problem here. Thanks Very Much to Wade Macdonald who helped me solve this issue.
    Some of you may know that I have been reporting a problem with garbage renders from FCP.
    For the benefit of the world I am reporting my workflow here to help anyone else who runs into this.
    1. Edited in FCP with transcode OFFLINE media created with clipfinder (or redrushes)
    2. Exported XML file of FINAL FCP SEQUENCE
    3. Opened Clipfinder and ran CONFORM FCP PROJECT with XML file to create NEW file.
    IT IS VERY IMPORTANT NOT to rely on the RESIZE the SEQUENCES to 1920x1080 in clipfinder.
    4. Opened NEW XML in FCP and set the sequence by hiting apple key "0" to the following. CUSTOM 2048x1024, 23.98, etc
    5. used SEND TO COLOR command to open sequence in COLOR
    6. CHANGE floating point to 10-bit in COLOR
    7. Change EXPORT size of FINAL project in USER settings (it is very important to do this set within COLOR or it will not work!)
    ***ADDING TWO THINGS HERE to eliminate any frozen renders you might get. (DOWNLOAD LATEST VERSION OF BETA CLIP FINDER)
    8. Close Color project
    9. Open Clipfinder
    10 In the tools menu run the Color Project through "FIX LOOPING BUG IN COLOR PROJECT"
    11. Reopen in Apple Color and proceed.
    You now have FULL access to the R3D files and can use the RED TAB in Color and render out great Prores 4444 or Uncompressed without any problems.
    MORE INFO AT THIS LINK AS WELL
    http://reduser.net/forum/showthread.php?t=40628
    I am so glad I finally solved this nagging issue.
    David
    "A revolution is not a bed of roses.
    A revolution is a struggle between the future and the past." – Fidel Castro
    Senior Member Tim Whitcomb's Avatar
    Jan 2009
    Portland, OR
    woot! thanks for Sharing David
    Kind regards,
    Tim Whitcomb
    Filmmaker
    Jan 2007
    Thanks David!!!
    Senior Member jimhare's Avatar
    Sep 2007
    Sydney Australia
    Good On'ya David. Great tip.
    Norway
    Do you have an ATI or nVidea card in your Mac?
    (My bet: nVidea...)
    Life is good. So is RED...
    http://youtu.be/mhFB1CMzQBM
    http://bit.ly/mCwcoN
    Twitter: gunleik
    With the NVidias we have its 8bit or Float .. 10bits ghosted out.
    s
    MatteBlackFilms
    Space Digital Visual Effects & Post Production
    Quote Originally Posted by Gunleik Groven View Post
    (My bet: nVidea...)
    It's an ATI Radeon HD 2600 256MB of ram.
    David
    Junior Member
    Mar 2009
    Quote Originally Posted by David Battistella View Post
    Hi all,
    IT IS VERY IMPORTANT NOT to RESIZE the SEQUENCES to 1920x1080 in clipfinder.
    David
    Hi David,
    I'm interested to know why you export an xml then conform in clipfinder ??
    I have had great results just editing H proxies on a 2k timeline then "send to color" from fcp. Then close Color use Colorfixer to fix project, then simply open Color & grade then send back to Color apple pro res.
    Cheers
    David,
    Why are you using 10 bit internal processing in Color? Was there a problem using 32 floating point? Thanks.
    Michael
    You must use 10 bit internal. I have not tested the 32 bit, but the the FCS whitepaper tells you to change it to 10-bit as part of the process.
    David
