Thread: Clipfinder: 'Run Conform on FCP XML'
Results 1 to 6 of 6
  1. #1 Clipfinder: 'Run Conform on FCP XML'
    Junior Member
    Jul 2009
    Hi everybody!
    I'd like go use the function 'Run Conform on FCP XML' in Clipfinder. Problem is: The clips are stored on two different drives and it seems like clipfinder only allows one location for these clips. Does anybody now a 'workaround'? or maybe creating the XML-file in two steps? Any ideas would be great.
    jp
    The Clipfinder 2.2 beta allows multiple clip directories.
    Hans
    Quote Originally Posted by jpred View Post
    Hi everybody!
    jp
    A sneaky way is to create a symlink for one drive (or folder) in the the other drive (or folder).
    symlinks for dummies below:
    Start Terminal and write
    cd
    put a space after the "d"
    then in Finder drag Drive1 into the terminal window
    it should now read something like:
    cd /Volumes/Drive1
    press Enter
    now write
    ln -s
    put a space after the "s"
    then drag Drive2 into the Terminal window.
    The Terminal window will then display something like this:
    ln -s /Volumes/Drive2
    write
    Drive2_link
    (or something similar - spaces are not allowed)
    The full command should read:
    ln -s /Volumes/Drive2 Drive2_link
    Press Enter
    Now you will have an alias to Drive2 in Drive1 that is more powerful than the normal alias you create in Finder...
    EDIT: Or you can upgrade to the Clipfinder 2.2 beta. Formatting takes time. So much time that the author sneaks in between the OP and my answer :)
    Braunschweig, Germany
    Regards,
    Uli
    My Red is called Vertov after a Russian avantgarde filmmaker, a pioneer in modern cinematography, a true revolutionary who later suffered under Stalin's bureaucracy.
    Or if you don't want to pay $14 for a simple UNIX command GUI. Get SymbolicLinker:
    http://www.macupdate.com/info.php/id/10433
    Junior Member
    Jul 2009
    Thank you for all the answers! You are great help!
