Thread: SALT Results... (Part 1, Results)
Page 11 of 11 FirstFirst ... 7891011
Results 101 to 109 of 109
  1. #101
    Senior Member Dennis Guskov's Avatar
    Feb 2007
    Moscow
    Quote Originally Posted by Kevin Marshall View Post
    ah! thank you
    Evin, any plans to do more tests, for lenses that escaped from you the first round? I find what you did very insightful, especially considering opinions from all the contributors with their different backgrounds and ways to compare and measure differences between lenses.
    Right now I am torn between purchasing RPPs and Illumina S35s. Both seem good options for people on small budget ($27K for T1.3 18mm, 25mm, 35mm, 50mm, 85mm). But I absolutely NEED to know what you guys think about the Illumina lenses to make up my mind :-) what are their strengths and weaknesses??? Will they even cover Epic S35 @ FF?
    Feb 2007
    Moscow
    Quote Originally Posted by Dennis Guskov View Post
    After speaking to the manufacturer of Illumina lenses I was told that the existing 5 lenses were designed and built with 31.8mm image circle and will not cover Epic's 34mm. He did not specify which lenses in the set exactly, but did say that they are planning to design and build 14mm and 135mm lenses to add to the set (around this time next year) and will keep in mind Epic's larger sensor.
  3. #103 Epic's recorded ....
    Senior Member Jacek Zakowicz's Avatar
    Jun 2008
    Area is naturally smaller than whole sensor. According to AbelCine 29.7mm so yes the lenses will work..
    Jacek Zakowicz, Optitek-dot-org, jacek2@optitek.org
    Professional Broadcast and Digital Cinema Equipment
    Feb 2007
    Moscow
    Quote Originally Posted by OptiTek View Post
    @ 5K 16x9, yes, which is 4800 px horizontal
    but that is not as wide as it goes. at max rez it's 5120 horizontal so the circle is also wider
    Senior Member Timur Civan's Avatar
    Jan 2007
    New York City
    I wish the Panchros could have been a part of this. Would love to see what all you guy think of them.
    Director Of Photography
    RED Epic M - Fujinon Cabrio 19-90 T2.9 - Oconnor 2060 + accesories
    www.TstopCinema.com
    Timurcivan@gmail.com
    9175894424
    Apr 2009
    Toronto, Canada
    Great, informative and interesting test guys, thanks for taking the time to do it and write it up. Some really interesting stuff here.
    Kevin Rasmussen
    Cinematographer
    Toronto, Canada
    collectivevolution@gmail.com
    www.collectivevolution.com
    Feb 2007
    Moscow
    Had a chance to test the Illumina S35 lenses with Epic and indeed 18mm does show slight vignetting at 5K FF. Other lenses in the set covered OK.
    Senior Member Paul Russell's Avatar
    Sep 2011
    Malaysia and Singapore
    that chart explains why 5D shooters constantly struggle with depth of field, while the 7D has become more popular.
    Feb 2007
    Moscow
    I thought I'd link this thread to the Portland Lens Test thread for more lens tests: http://reduser.net/forum/showthread....-LENS-SHOOTOUT
