Thread: exporting entire film as organized dpx sequences
Results 1 to 3 of 3
  1. #1 exporting entire film as organized dpx sequences
    Senior Member MiguelOrtega's Avatar
    Jul 2007
    half MT
    is there a way to export my edited short film out into folders as organized dpx sequences from premiere. "so each shot would be in its own folder" OR a way to rename each individual shots from within premiere to export with custom naming per shot would be good enough if i cant put them in folders.
    i brought in the raw r3d files, i have the edit done, and i know i can do it in redcine but im asking about about premiere
    Miguel Ortega
    Creature FX Artist
    http://www.monstersculptor.com
    Red # 1995
    Junior Member
    May 2007
    Premiere does not export dpx files.
    You need to pass the files to AE via dynamic link and then export dpx files.
    Watch the RED tutorials for CS4.
    Apr 2009
    Prague, Czech Rep.
    should You want to have dpxes for each shot used, so that .. say transitions could be reconstructed later in Lustre or whatever grading SW as typically are when using common Avid>Lustre EDL workflow, where one obviously needs the shots separated and not blended together during the transition effect, I worry it is not possible.
    Simply - once You edit in premiere or AFX, You can only output final sequence as one series of DPXes. Otherwise You'd have to export each shot manually adjusting export in/out points in AFX, which certainly is unacceptable.
    pro.bistudio.com - MoCap, RED One, 3D scanning
