Thread: bellows options for RR Mattebox?
Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 31
  1. #11
    Senior Member Larry McKee's Avatar
    Jan 2007
    Houston, TX
    There is no way to go any closer without RR redesigning their housing. I have used it with my 20-120mm Angenieux zoom in 4K and my 9.5-57mm Angenieux zoom in 2K without any vignetting problems even with the 3rd stage in place. I haven't tried it with anything wider, so I don't know how much below 20mm I can go without issues.
    Epic-X 1136
    Jan 2007
    ashland, oregon
    Hey Larry,
    Are you pleased with the results out of the little 6to1 for 2k? That little lens was way ahead of it's time, espically with it's fast stop.
    CHUCK
    Jan 2007
    Houston, TX
    Chuck, I have shot entire projects with that little lens. It is great. My clients have been very happy with the images.
    Epic-X 1136
    Jan 2007
    ashland, oregon
    Yeah I thought so. I bought a handfull of them when I ran tech ops at UCLA film school. Another lens around that time was the Angenieux 16-44. It was also high speed and sharp.
    Here is one. I don't know if I would pay that much but they are relatively rare.
    http://cgi.ebay.com/0873-Angenieux-Z...%3A1%7C294%3A5
    Here is one for a lot less dough.
    http://cgi.ebay.com/ANGENIEUX-16-44M...3A1%7C294%3A50
    CHUCK
    Senior Member Alex Carr's Avatar
    Aug 2007
    planet Earth in the Milky Way Galaxy
    I took a dremel to my RR, only I used a 6x6 Bellows w/ a 138mm. I fashioned my own screw to tie the Bellows in. The rubber donuts dont work, and really suck.
    , it at least now holds a 138mm.
    Quote Originally Posted by Alex Carr View Post
    can you share some closeup pics?
    Quote Originally Posted by Larry McKee View Post
    I took a Dremel to the donut housing and opened it up 2mm so I could fit the bellows from my 4x4 Chrosziel. It works perfectly.
    Attachment 10430
    Attachment 10431
    Thanks so much for the pic. Is the bellows removeable? or permanent? how do you keep it securely in place?
    Banned
    Brian Valente,
    I'd rather you guys made one of these bellows receivers that fit closer to the back 4x5 stage and has the standard ball bering clip-in method.
    Jan 2007
    Houston, TX
    Tonaci, the bellows is removable. I can go back to using the original donuts if I need to. I was careful not to remove too much of the opening in the housing so the bellows would be tight enough to stay in place, but not so tight that it couldn't be easily removed.
    BTW, the bellows accommodates a 138mm round filter. I failed to mention that in the earlier post.
    Epic-X 1136
    Senior Member Damien Molineaux's Avatar
    Geneva | Switzerland
    Quote Originally Posted by Brandon View Post
    Thanks guys. That's too much for me spend now, but I'm still interested to see how it works. anyone have any pictures or anything? How is the arri set different than the rubber donut?
    THANKS! :)
    Quote Originally Posted by tonaci View Post
    yes, I second that.. would love to see how this setup looks and works.
    The rubber dougnuts become a pain when you are on long shoots..with a multitude of lens changes a day.
    Hi fellas,
    Here are a couple pics of my RR Mattebox with Arri bellows, including 138mm filter support, 100mm and 80mm adpators.
    Damien
    www.c-sideprod.ch
    camera rental and post services
    www.earthling-prod.net
    filmmaking around the world since 1999
    www.kinogeneva.ch
    participatory filmmaking laboratory
