Thread: Red and 4:4:4
Page 1 of 3 123 LastLast
Results 1 to 10 of 21
  1. #1 Red and 4:4:4
    In order to try and clear up some confusion and help people understand why "4:4:4" notation (chroma subsampling notation) is inappropriate when talking about the Red, I've written this. Thanks to Graeme for his comments and suggestions. Hope it helps.
    29.Oct.2008: I've updated it with a few changes based on people's responses.
    Why 4:4:4 has nothing to do with the Red One camera
    History
    First, a bit of history. Originally, there was black & white television. Then came colour. To accommodate black & white televisions, colour was added to the original luma (brightness) signal through a new chroma (colour) signal, thus keeping colour separate and black & white televisions viable. In addition to making sure that black & white televisions were still useful, this was also an intelligent division of the visual data because less bandwidth was used for the chroma signal, which the human eye is much less sensitive to compared with luma.
    YCbCr
    In the digital world, the standard for separating luma and chroma is the Y'CbCr colour space Y represents luma (gamma-corrected), Cb and Cr are used for blue and red channels. The green colour information is derived mathematically. As stated above, the human eye is less sensitive to colour information than brightness information. Naturally, digital video could also use this fact to save bandwidth. In digital video, the process of reducing chroma information translated into subsampling that is, decreasing the resolution for the chroma channels.
    Subsampling
    Analogue television used much less bandwidth for the chroma signal than the luma approximately one quarter. So the effective ratio of bandwidth would be 4:1, with the luma signal using four times the bandwidth of the chroma. The same effect is achieved in digital video through subsampling reducing the resolution. Due to the original, analogue numbers, subsampling uses a 4 to describe a full-resolution (luma) channel. To achieve subsampling the chroma resolution is cut to one half or one quarter. Chroma subsampling notation describes this as 4:2:2 and 4:2:0 (or 4:1:1), respectively. The first number is the luma channel and the second and third numbers are chroma channels (Cb and Cr). Normally, this describes the horizontal sampling per scan line. However 4:2:0 is a special case that indicates the chroma channels are halved both horizontally and vertically. So, a subsampled 4:2:2 or 4:2:0 image will either have lost half or three quarters of the original chroma data.
    RGB
    YCbCr is a way of storing colour visual information that is, a colour space. RGB is another colour space. RGB, of course, stores the information in a completely different way. Instead of separating luma and chroma, all the information is derived by mixing red, blue and green channels. As RGB is not designed to separate the chroma information, it is not suited for chroma subsampling.
    Bayer Pattern
    A CMOS image sensor most often uses a Bayer-pattern filter to produce colour information (like Red's Mysterium). The Bayer-pattern filter divides the light into red, green and blue (like RGB), so that each photosite captures one of the three colour channels. However, since a photosite only captures one channel and yet correlates to one pixel in the output, the RAW data saved is not RGB. It is Bayer-patterned RGB, which can be called "GRGB". The two G's in GRGB refer to the fact that there are twice as many green photosites as red or blue. Green is favoured because the human eye is more sensitive to green light. To get an RGB image from GRGB data, RGB data has to be re-constructed through a process called demosaicing. There are several approaches to this and getting the best result is both a science and an art.
    Conclusion
    Demosaicing and subsampling are performed in completely different colour spaces, GRGB and YCbCr, respectively. They are also two very different processes. Subsampling reduces bandwidth by reducing resolution. Information is lost in that process. Demosaicing, on the other hand, is a method of interpolation in which none of the existing data is compromised.
    The Red One does not perform chroma subsampling, nor does it operate in Y'CbCr colour space. The RAW data captured by the camera and stored as Redcode RAW is Bayer-patterned RGB (GRGB) and this data is demosaiced into RGB data. It is therefore meaningless to use subsampling notation when discussing the quality of the Mysterium sensor, the quality of native Recode RAW footage or demosaiced Redcode footage. It would only be appropriate if the image data were later converted to YCbCr colour space, in which case, the user has complete control of the quality.
    Member Rolf Heiler's Avatar
    Jul 2008
    Stuttgart, Germany
    Great explanation. This is the first time to me, to understand the difference between RGB and YCbCr. But what impact have different red codecs for the debayering quality?
    RHeiler
    Senior Member Radoslav Karapetkov's Avatar
    Jul 2007
    Sofia, Bulgaria [EU]
    Great post indeed.
    EveryOne is the One...
    Nice consice description.
    Birns and Sawyer
    www.birnsandsawyer.com
    Your Vision. Our Gear.
    Camera Sales and Rentals: (323) 466-8211
    Lighting and Grip: (818) 766-2525
    Quote Originally Posted by lightman View Post
    The Red One does not perform chroma subsampling and it operates in RGB colour space. The RAW data captured by the camera and stored as Redcode RAW is Bayer-patterned RGB and this data is demosaiced into full RGB data. It is therefore meaningless to use subsampling notation when discussing the quality of the Mysterium sensor, the quality of native Recode RAW footage or demosaiced Redcode footage. It would only be appropriate if the image data is later converted to YCbCr colour space, in which case, the user has complete control of the quality.
    While what you say is technically correct, the fact is that in a Bayer pattern sensor, there are half as many photosites devoted to blue and red as there are to green. Since most of the detail information captured by cameras and by human eyes is in the green spectrum, this basically means that the actual capture is, in effect, subsampled in red and blue. The RGB image that is the product of debayer and reconstruction is valid, but it is interpolated, not captured - which is why the debayer and reconstruction algorithms used are so critical. I'm not saying there's anything wrong with this, but it is simply a fact that the sensor itself does not capture all three components at the same sampling rate.
    The basic premise of your post that 4:4:4 and 4:2:2 are basically video terms that describe YCbCr color space is true, but in many peoples minds, the numbers basically mean that all three color components are either sampled at the same rate or they're not. A simplistic view, and not necessarily technically correct, but a commonly held view nonetheless. And the use of a Bayer sensor does imply that two of the color components are not sampled at the same rate as the third.
  6. #6 Short sweet and to the point
    Thank you for "turning on the light". This was not clear to me until now.
    Thommes.
    Banned
    Very enlightening man. Thanks for posting this in such a reader-friendly way.
    Quote Originally Posted by mmost View Post
    The point of this is to try and help people understand the terminology and (to some small extent) the technology - not to accept a common error. Hopefully that can help prevent misuse of the terminology and subsequent misunderstanding.
    Subsampling and demosaicing are two very different processes requiring very different approaches. It is inaccurate to assume that separating light rays into one of three RGB channels for capture in a photosite is effectively the same as reducing the chroma resolution of existing Y'CbCr data. That is a crucial point. Subsampling and the Bayer pattern both have advantages and disadvantages in their own fields. However, a direct comparison between the two is impractical and of little value.
    Back to subsampling notation, it is simply the wrong approach when dealing with Bayer-patterned data.
    First, chroma subsampling notation does not refer to three colour components, nor should it be used to do so. It refers to luma and chroma. Subsampling is reducing the amount of colour information in the image to save space. Thus, it begins where there is already more information. That is an important distinction: existing digital image information is actually sacrificed to save space. This does not occur in a Bayer-pattern CMOS. So, the Red One never has more information than is provided by the RAW Bayer data.
    Secondly, the subsampling process requires the separation of chroma and luma (via Y'CbCr) because only colour information is subsampled. Bayer is, as stated, RGB. The Bayer pattern favours green, but every pixel is still captured as a colour channel (R,G,B). There is no separation of luma and chroma.
    So, once again, using chroma subsampling notation does not make sense, regardless of the distribution of colours by the Bayer pattern. Both requisites for using subsample notation are not met: chroma and luma are not separated and data is never subsampled.
    Quote Originally Posted by rheiler View Post
    RHeiler
    Thanks!
    Do you mean Redcode 28 and Recode 36? That's an interesting question. The compression probably has some impact on the demosaicing process, but I'm not sure what that impact might be. Redcode may be fine-tuned for Bayer data, which would make it hard to compare without being able to compress in it.
    However, if you want to get an idea of the compression quality, you can try doing compression tests yourself with another wavelet CoDec (JPEG 2000 comes to mind). That will demonstrate how visually lossless such a CoDec can be. From my tests, the results are rather impressive.
  10. #10 Rgb 4:4:4
    ...but in many peoples minds, the numbers basically mean that all three color components are either sampled at the same rate or they're not.
    The point of this is to try and help people understand the terminology and (to some small extent) the technology - not to accept a common error. ...
    Back to subsampling notation, it is simply the wrong approach when dealing with Bayer-patterned data...
    I have never been in a competent technical discussion about 422/444 regarding a RED shoot...yet, only here. It is usually customer talk, amateurish questions, as color space and subsampling is more for us tech geeks really. And they ask the questions different or know it anyway.
    People asking about 444 want to know more if it is like "full quality" - that is what they associate it with.
    They just know 444 is the full package, the best, which is quite right, not ?
    Is RED like 444 is the question I faced a couple of times. They don't know the difference to 422 and how much the keying is really better in 444 or not.
    I always try to deal around with it and say, it is different, more like DSLR, other chip-pattern which doesn't apply to this kind of terminology...
    But it is easy: Compared to a true 4K RGB, no, RAW is not the full package. Not like a 444 image in 4K would be. Not that sharp, not the same color resolution. Yes, we might have 4K pixels, but they are RAW, there's not 4K res in. And in this regard, the term might be wrong, but the understanding is right and a question and comparison does make absolutely sense - in its own way.
    ...First, chroma subsampling notation does not refer to three colour components, nor should it be used to do so. It refers to luma and chroma.
    So, once again, using chroma subsampling notation does not make sense, regardless of the distribution of colours by the Bayer pattern. Both requisites for using subsample notation are not met: chroma and luma are not separated and data is never subsampled. ...
    While 422 usually stands for YUV color space without further prefix, the terminology itself works also in RGB colorspace where 444 stands for full raster and no further reduction via color subsampling.
    Your post is very elaborate and well researched and expressed - the statement color subsampling term would only apply to YUV colorspace is not absolutely correct though, at least not for RGB 4:4:4.
