Thread: how to adjust olf OLED EVF in IPP2
Page 1 of 2 12 LastLast
Results 1 to 10 of 17
  1. #1 how to adjust old OLED EVF in IPP2?
    Senior Member Luka Sanader's Avatar
    Jan 2013
    Montreal
    Hello folks i have quick wuestion for you experts. i got Bomb OLED that is in like new condition, however image is horrifying. brightness feels like its on 110%, blacks are millked out , contrast is low and colors are washed out... i have tried different cables, different ports and adapters, regardless of what i do its always the same.
    last time i have used Bomb was on DSMC1 add legacy IPP and i remember that there was a gamma curve that could be applied to the output but i also remember there was some issue with SDI out... anyhow i was not able to fined any settings on my Helium, i am running 7.4.1 build
    if you have any tips i would appreciate it. also isn't there a some PDF user Manuel that came with Bomb? i cant find any on Red page
    thanks
    Epic-W Helium 8k #6819
    Mar 2011
    Toronto, ON Canada
    Just curious which bomb you have? There are a few versions.
    ___________________________
    10 frame handles
    Vimeo
    Instagram
    Senior Member Brendan H. Banks's Avatar
    Jun 2009
    NYC
    YOu can do brightness in the Monitoring menu and select which port and EVF. In the newer firmware builds, you'll also find what color pipeline you're getting in your EVF. When I do IPP2 it somehow defaults those values to a random format and I have to go in and change it. I'd start there.
    Brendan H. Banks
    Cinematographer
    Local 600 IATSE
    DSMC2 Gemini #796
    Jan 2013
    Montreal
    Hi Bob ia dont knwo how many of the submodels of OLED there is and i have no clue how to tell them apart . this is mine
    its sso strange that there is no user manuel or any tec documentation on this EVF.
    Jan 2013
    Montreal
    Quote Originally Posted by Brendan H. Banks View Post
    thanks i will try as you suggested
    Mar 2011
    Toronto, ON Canada
    There was never a separate manual but there was something small in the DSMC1 manual:
    https://www.manualslib.com/manual/45...page=37#manual
    10 frame handles
    Vimeo
    Instagram
    Jan 2013
    Montreal
    thes is so strange! How much id they sale this EVF for? 3000$ or so and yet there is not a user guide. average 10$ hot water kettle comes with a booklet in 5 languages but this professional device has no manual, pats numbers, nothing... strange
    Oct 2010
    Sounds like you're experiencing the same thing discussed here -
    http://www.reduser.net/forum/showthr...-settings-poll
    Senior Member Bérenger Brillante's Avatar
    Dec 2007
    Paris, France
    Depending on the situation, the contrast is a blessing, or not. They should really create a checkbox to let users choose through the Monitor/EVF menu.
    That's not really the bomb this EVF.
    The real Bomb EVF is the next one. For DSMC².
    Bérenger B. Brillante
    --Director Showreel--
    Oct 2009
    my assumption is that the issue is the video feed being sent to the evf is not optimized for OLED, so they just milk it out.
    But red tech support told me the Bomb EVF WAS TOO DARK in the shadows on DSMC1, so they made the DSMC2 oled more milked out.... but considering you are seeing the bomb evf milked out on a dsmc2 body, then perhaps my assumption is correct that the DSMC2 body sending the evf a signal is the culprit.
    Ps
    that means, the brand new Red Ranger Gemini is not getting a firmware update to make the evf look right. shame for red to release a camera that is then immediatley considered out dated. i tried to test the camera before buying, but this was one of those aspects i overlooked, and buy the time i actually used the camera, the return policy had expired.
    Ranger Gemini
