Thread: Teradek Bolt 4K LT 750 3G-SDI/HDMI Wireless Transmitter and Receiver Kit
Results 1 to 5 of 5
  1. #1 Teradek Bolt 4K LT 750 3G-SDI/HDMI Wireless Transmitter and Receiver Kit
    Senior Member Brian Pascale's Avatar
    Nov 2011
    Silver Spring, Maryland
    What are people’s thoughts on the Teradek Bolt 4K LT 750 3G-SDI/HDMI Wireless Transmitter and Receiver Kit. Is this best in class? Is there a better system I should be considering?
    Komodo
    Brian Pascale
    Nov 2009
    Well...
    Depends on the camera and if you need 4K
    If you’re sending 4K HDMI this will send 4K.
    3G Sdi will not carry 4K. Right ?
    What camera are you using ?
    What range do you need?
    Is 4K Sdi a need now or in your future ?
    You can get a Paralinx Tomahawk for nothing these days.
    Personally, I want a 4K SDI H.265 pipeline capable WiFi based transmitter with a sub 20ms glass to glass Sdi / hdmi decoder box, which iPhones and iPads can decode at sub 40ms latency.
    Something like a Teradek Swerv2 4K...
    Nov 2011
    I don’t really need 4K. 500 feet is probably long enough. Yes, only hdmi has 4K, Sdi does not. This system seemed like a good value but I have seen sub $1,000 systems that would fit my needs if the quality is there.
    Komodo
    Brian Pascale
    I'm using the bigger brother Bolt 4K SDI and I have to say the video quality is very noticeably higher quality. I did some frame capture and diffs on the images to confirm my suspicions. As far as I know these are the same general chipset and encoder.
    phfx.com IMDB
    PHFX | tools
    2X RED Monstro 8K VV Bodies, 1X RED Komodo, and a lot of things to use with them.
    Data Sheets and Notes:
    Red Weapon/DSMC2
    Red Dragon
    Nov 2009
    Decent value proposition here...
    https://www.bhphotovideo.com/c/used/...waAml4EALw_wcB
    Although...
    I might be inclined personally to buy this transmitter:
    https://www.bhphotovideo.com/c/produ..._sdi_hdmi.html
    And this receiver:
    https://www.bhphotovideo.com/c/produ...50_3g_sdi.html
    Seems like a viable way to get 4K SDI out of a Komodo and pipe it to a 4K input on a onset client monitor or even like an LG OLED TV...
    Seemingly lower frustration way of being future resistant and having interoperability with other ‘deks of the 4K variety for future
