Thread: Only one choice: A7r3 or Bmpcc6k
Page 1 of 2 12 LastLast
Results 1 to 10 of 18
  1. #1 Only one choice: A7r3 or Bmpcc6k
    Oct 2017
    FF vs S36
    4K vs 6k
    If you could choose only one of these two cams?
    Hopefully Komodo but seems though quiet on productivity front...
    May 2010
    New Zealand
    I own an A7R 3 for photography and have used the sony for a couple of video shots when I needed a small camera. The videos files are very thin, hard to grade the log footage, I was pretty unhappy with the camera. Later I purchased a pocket 4k for the times I needed a small camera and even though its a painful design, the files and workflow blow the sony away. I prefer the pocket 4k (over the 6k) as it can be close to full frame with a speedbooster, its cheaper and 4k is all I have ever needed, I'm already swimming in far too much- expensive to store data.
    Senior Member Patrick Tresch's Avatar
    Aug 2007
    Switzerland, Lausanne
    The answer A7s3 :-)
    Senior Member Zack Birlew's Avatar
    California and Las Vegas
    The A7RIII would be great for stills but other than still resolution and Full Frame sensor coverage, you would be missing out on video with 8-bit in a time when 10-bit is becoming the new standard and that's at the minimum! The Blackmagic Pocket 6K offers cinematic S35 footage that is a stone's throw away from 8K so that will help be competitive and complementary if used as a B-camera, especially combined with one of those awesome Arri Alexa LUTs, but doesn't offer nearly as much in the stills department. I like the A7S III idea but if you need stills, 12 megapixels might not be enough even if the processing is stellar and, again, it's just 4K when 8K is going to be the new norm soon.
    The A7S3 is the best camera under $20k. It's insane how good it is. The FX6 will probably be worth the cost increase just for the amazing ND and proper audio inputs.
    Senior Member Aaron Green's Avatar
    Jan 2016
    Chicago
    A7siii
    Aaron Green - Chicago, IL
    www.instagram.com/aaronkgreen
    Senior Member Joel Arvidsson's Avatar
    Nov 2008
    Sweden
    How about, canons c70? How does it compare to A7siii. Wich holds up better for gradeing? Looking for tiny gimball camera with great autofocus.
    Epic #06696
    Epic-W #004069
    My vote is for A7S3.
    Aug 2007
    Just sent my A7s3 for dead pixels in... has anyone also experienced it?
    Patrick, did you do a hot pixel refresh? I know my original A7S has needed that sometimes from going to high ISO and back frequently over time.
