The minimalist design of the Komodo is driving me nuts. Who has a good solution for putting a Komodo on an emotion head using a focus motor and a KipperTie chinstar (to keep some nice PpL glass from ripping the face off the Komodo)?
Problem #1: the emotimo's L bracket strangely aligns perpendicular to the lens, not down the barrel, which means that the Komodo's inbuilt pair of receivers cannot be used to keep the camera from twisting away from the applied torque of the focus motor. And it doesn't help that the central receiver on the bottom of the chinstrap greatly lengthens the longitudinal stability of the camera to better prevent twist.
If the chinstrap had 1/4-20 receivers drilled on the bottom of the chinstrap to either side of the 3/8-16 central receiver, that would be grand and solve the problem.
What sort of gack are you putting on the bottoms of your Komodos so that they can interface to a world not fully turned upside-down, but rotated far enough to to right that nothing that should be easy really works anymore.
And yes: I am cranky about this!
