Thread: Komodo robust clean sound?
Results 1 to 8 of 8
  1. #1 Komodo robust clean sound?
    I’m looking into getting a Komodo, my main hesitation is getting audio into the camera.
    Is there an audio hardware box that doesn’t go through the 3.5 mm jack to supply pantom powered XLR’s? Or any recommendations to get high quality camera sound? My main concern is if the cable on the 3.5 mm gets pulled out or damaged then there would be no way of telling whether there is sound. Are there sound bars on the Komodo display?
    Hi Matt,
    Yes, there are audio monitoring levels on screen for Komodo that you can also have on the overlay sent to an external monitor.
    You can use any pre-amp or mixer with a 3.5mm out to Komodo. As you mentioned, Komodo doesn't have phantom power via the 3.5mm.
    Best non-recorder pre-amp I've used is the Sonosax M2-D2. But there are many more budget minded ones out there. Beyond that you can feed audio from Sound Devices, Zaxcom, Zoom, etc.
    phfx.com IMDB
    PHFX | tools
    2X RED Monstro 8K VV Bodies, 1X RED Komodo, and a lot of things to use with them.
    Data Sheets and Notes:
    Red Weapon/DSMC2
    Red Dragon
    Member Stu Mannion's Avatar
    Jul 2008
    Melbourne, Australia
    I went with a German made preamp called Kortwich MM2. Phantom power, compressor.
    Hi Matt,
    I've used the Beachtek DXA-RED 2-Channel Preamp with my Komodo.
    It's powered over dtap and has some operational quirks, but sounds great!
    https://www.bhphotovideo.com/c/produ...h_phantom.html
    Good luck!
    Reuben
    Senior Member Christoffer Glans's Avatar
    Jun 2007
    Stockholm, Sweden
    Quote Originally Posted by Matt Gerrand View Post
    Since Komodo is a cinema camera and not a video camera I would recommend external recording. Even if you want to attach the stuff to the camera and do that kind of thing that's more related to video, I think you will get a much better result by recording to a specific recorder attached to the camera instead of using the sound going into the camera. You can just have a small cable for reference audio going from the box into the camera and then with one click in editing like Resolve you sync between the two using waveform.
    That will give you the best audio quality, hands down. Maybe check out the zoom 32 bit recorders and you won't have to check the gain while recording.
    "Using any digital cinema camera today is like sending your 35mm rolls to a standard lab. -Using a Red is like owning a dark room."
    Red Weapon 6K #00600 Red Komodo #002397
    Oct 2014
    Auckland, New Zealand
    Get yourself a Sound Devices MixPre3mk2 (or Perhaps Zoom F6), record externally, while sending a scratch to the camera. Sync in post. Done. Easy.
    http://IronFilm.co.nz/Sound/ (Sound Recordist based in Auckland, NZ. Happy to travel too)
    https://www.youtube.com/c/SoundSpeeding
    Jun 2007
    Stockholm, Sweden
    Quote Originally Posted by David Peterson View Post
    Do you know any good ways to send wireless audio to the camera? Been thinking about it, but the problem is latency. If the sound has latency through wireless, it will be out of sync when later synced in post.
    But the MixPre3mk2 has timecode as far as I know, so that would be far superior in my opinion.
    Jan 2015
    Quote Originally Posted by Christoffer Glans View Post
    To be clear, are you asking if the wifi capabilities of Komodo allow wireless audio input? Or are you asking for opinions on the best wireless audio systems out there (e.g. specific Lectrosonics transmitter-->Lectro receiver-->Sound Devices mixer-->Komodo)?
    The idea of built-in wireless audio capabilities for Komodo is exciting, though I'm not aware of a protocol for that. Certainly you're right about the challenge of latency.
    It's exciting to imagine a powerful unified wireless I/O unit that would allow the capabilities we currently get from a mixture of wireless systems (that require their own physical units, power supplies, incompatible receivers...)-- near-zero latency, delivery-quality video transmission, sound transmission, and device control.
