I picked up a Focus Pro Komodo monitor today.
Impressions so far, less than impressed. Not so much as a monitor, but as far as usability goes.
So far I have not been able to get the Small HD to communicate with the Komodo at all. Small HD powered by battery, Single cable provided by Small HD, plugged into USB and the other end plugged into EXT on Komodo. (This brings up concerns which I will talk about in a minute)
I have registered the SamllHD with the Komodo Control License (very convoluted way of going about this IMO)
When I go to the page "Connect to a RED KOMODO camera", and press connect, it tells me the connection failed, and to check the cable. Currently SmallHD is closed and there is zero info in the manual about this process.
Is there something I need to change on the Komodo settings?
Concerns.
By plugging in this monitor, it uses the same port as the breakout box for Genlock,GPI and timecode. Am I to understand, if I have camera control through the monitor that I can no longer jam timecode? That seems like an odd option to have?
Am I missing something here? This seems like a very convoluted system for having camera control on a monitor (Don't get me started on the fact that the SmallHD monitor has no SDI output, so basically, plugging this monitor in, means I get no timecode and no secondary SDI out.
A little frustrating.
Yes I know...Komodo = Crash cam, blah blah etc, but there is some basic functionality that seems to be missing (or maybe I'm just not doing it right, very possible). Even Crash cams should be able to receive timecode.
