Use ARRI's BP-8 Bridge Plate Kit to balance your camera and to support 19mm rod-based accessories. The kit consists of the BP-8 sled, a 12" bottom dovetail plate, and a 17" pair of 19mm support rods. Directly compatible with the ARRI ALEXA Studio, the Sony F65, and the Phantom Flex4K, the BP-8 Kit can be adapted for use with the ARRI ALEXA Mini, AMIRA, and many third-party cameras (adapters available separately).
ARRI Bottom Dovetail Plate (12")
This 12" Bottom Dovetail Plate from ARRI is used with a sliding bridge plate or sled to balance your camera rig. To prevent the bridge plate or sled from sliding off, the Dovetail Plate features a spring-loaded post on one end and a stationary stop on the other. The bottom of the plate incorporates 3/8"-16 threaded holes for mounting the dovetail to a tripod quick release plate or other support.
Use with a sliding bridge plate or sled to balance your camera rig (plate or sled not included)
Includes a spring-loaded post on one end, and a stationary stop on the other to prevent the bridge plate or sled from sliding off
Bottom of dovetail includes 3/8"-16 threaded holes for mounting to a tripod quick release plate or other support
ARRI 19mm Rods (Pair, 17")
This pair of 17" ARRI Support Rods feature a sturdy steel construction, designed to support heavier loads. Use them with any 19mm-based accessory or bridgeplate.
Hollow, sturdy steel construction with non-threaded ends
Compatible with any 19mm-based accessory or bridgeplate
The item is in very good, like new condition. Pictures of the item are available upon request. Thanks.
Bridge plate sold
Dovetail: $300 OBO
Rods: $120 OBO
