I'm debating whether to buy the Link Adaptor or not, it seems expensive for what it is, but being used to RED LCDs I'm not a big fan of most monitor options that require external power and just feel overly bulky for a build I'm trying to keep as compact as possible. I personally don't ever use false color, peaking, LUTs etc.. or any of the features of typical monitors, I just want as accurate an image as possible, and I find iPhone and iPads pretty damn accurate, my 11 Pro is probably the most accurate screen I own. In the brief testing I've done, I've found the Komodo Control App very useable, and the lag is very impressive. Honestly I'm just amazed it works as well as it does for something that is built into the body, it's great.
But the lag is there, and obviously the quality of the image is only as good as the signal, so it's not ideal for consistent operating. Has anyone purchased the adaptor and how have you found using an iOS device with it? Does it supply power to the device, if so have you noticed any significant drain on batteries? Are there any other uses you've found, such as ability to transfer files, or even record to an SSD?
