So I've never been forced to do a HDR grade, so never truly dipped my toes into it. But there will be a time where I need to do it so I've started looking into the entire process. So far, it's gone to hell.
I've watched a few Red HDR workflow clips on how to set things up, but it still doesn't work. Right now, I'm working with a Samsung Q9FN which has around 2000 nits 4K.
But the output doesn't look at all like within Resolve and I can't seem to get the settings correct. I'm doing a RWG/LOG3G10 workflow with the output LUTs from Red set to a high contrast very soft rolloff 2020 LUT. The idea here is to be able to grade something for rec709 and then switch out the output LUT for a 2020 LUT and have a proper HDR conversion of the same grade. But even if I only grade directly for HDR, nothing comes out correctly.
