Thread: Red Helium 8k 60fps Complete Camera Kit + Media + Power + AKS
Page 1 of 2 12 LastLast
Results 1 to 10 of 12
  1. #1 Red Helium 8k 60fps Complete Camera Kit + Media + Power + AKS
    Senior Member Grzegorz Gill's Avatar
    Sep 2010
    Los Angeles, CA
    Hi,
    I am selling my complete Red Helium Camera kit for $26,000 in Los Angeles that includes the following:
    1x Red Helium 8k 60fps Body
    1x Body Port Cap
    1x DSMC 2 Side Handle Port Cap
    1x DSMC 2 Standard OLPF
    1x DSMC 2 V-Lock I/O Expander
    1x Canon Titanium Mount + Cap
    1x Wooden Camera PL Mount + Cap
    1x DSMC 2 4.7 Inch Touch Display + cloth
    1x Wooden Camera 4.7 Sunhood
    2x Red 512gb Mini Mag
    1x Red Mini Mag Reader
    1x USB C Cable
    1x Red Mini Mag 4x Slot Case
    1x Wooden Camera Passthrough Top Plate
    1x Wooden Camera Easy Riser
    1x Wooden Camera 15mm Light Weight Bracket
    1x DSMC 2 Power Adapter
    2x Red Brick V-Mount 150wh Battery
    1x Red Brick V-Mount Charger
    1x Pelican 1510 + Dividers
    I am the original owner and this was purchased Nov 2016 as an Epic W and then upgraded to the Unified DSMC 2 Body and 8k 60fps specs on Aug 2018. This camera has been my work horse since purchase and will continue to produce for the next owner op. Only reason for sale is I need to liquidate this Red and corresponding accessories to make room for a set of Atlas Anamorphics.
    The camera has wear at the bottom of the body from baseplates coming on and off. The paint on the E has chipped away. Camera right side has small mark from accessories rubbing against the body like noga arms slipping. Body has no dents, never been dropped or mishandled except the mentioned scratches. Both pogo connections work just fine. I use a 4.7 touch on top, and a bomb evf on the left side. I have mounted a red side handle, and connections work as well. The rear contacts are clean and clear as I have used a dsmc2 v-lock i/o expander since original purchase.
    The media mounts and works, no errors.
    The 4.7 touch screen has no scratches, minimal pain chips from wear.
    I am including some original boxes from Red and the entire camera kit fits tightly onto a carry on Pelican 1510.
    The v-mount batteries charge and discharge normal, same goes for the charger.
    Included is the standard OLPF. The OLPF has never been taken off and is clean and clear. Firmware is up to date and the black shade calibration is auto, clean blacks and no dead pixels. Also to note the camera has never been in an underwater environment or any work with lasers. I've been a red owner/operator since 2012 and I take pride in taking care of my gear. This kit will work perfectly with no surprises saving you $10,000 cash if you were to purchase new.
    Operating hours as of 6.2.2020 is 1429
    Asking Price $26,000 - Location - Los Angeles
    Ebay Link https://www.ebay.com/itm/333596680413
    Below are items for sale only after the body is sold. I can bundle items for you as well, just let me know what you need.
    1x Red Canon Motion Mount - $1,700
    1x Red PL Motion Mount - $1,700
    1x Wooden Camera Tool Less Monitor Adapter - $100
    1x Red Bomb EVF LCOS - $650
    1x LCD/EVF Adapter A - $175
    1x LCD/EVF Adapter B - $175
    1x LCD/EVF Cable 18 Inch - $175
    1x LCD/EVF Cable 24 Inch - $175
    1x Wooden Camera 12 Inch Red Male Pogo to Male Lemo LCD/EVF Cable - $175
    1x G Tech USB 3 Mini Mag Reader - $136
    1x DSMC 2 Universal Top Handle - $100
    4x Red Brick 150wh - $1,000
    1x Red Brick Charger - $385
    Thanks,
    -GG
    Modest Helium Kit + Zeiss B Speeds
    -GG
    ggcinema.com
    Sep 2010
    Los Angeles, CA
    Additional Images
    -GG
    ggcinema.com
    Sep 2010
    Los Angeles, CA
    Additional images
    -GG
    ggcinema.com
    Sep 2010
    Los Angeles, CA
    Reserved for images
    -GG
    ggcinema.com
    Sep 2010
    Los Angeles, CA
    More images
    -GG
    ggcinema.com
    Sep 2010
    Los Angeles, CA
    reserved
    -GG
    ggcinema.com
    Sep 2010
    Los Angeles, CA
    Bump
    -GG
    ggcinema.com
    Sep 2010
    Los Angeles, CA
    Bump
    -GG
    ggcinema.com
    Sep 2010
    Los Angeles, CA
    Bump.
    -GG
    ggcinema.com
    Junior Member
    Sep 2016
    Brisbane, Australia
    Private message sent
