Thread: Wifi and foolcontrol issue, works again!!
Results 1 to 6 of 6
  1. #1 Wifi and foolcontrol issue, works again!!
    Hello
    I had the problem with my helium that disconnects foolcontrol from my iphone every 30 seconds, in the end I discovered why it happens
    I disconnected the auto calibrate sensor and left a black shading manual, it no longer disconnects anymore!!!
    Dsmc2 Weapon 8K CF & Dsmc1 Epic X owner...
    Camera, Movi, Drone, local producer service Ibiza.
    Studio, ciclorama, TupraStudio, film equipment service.
    http://www.tupra.es
    @tuprastudio
    although it is not clear to me if it is a foolcontrol or helium error??
    http://www.tupra.es
    @tuprastudio
    Senior Member Patrick Tresch's Avatar
    Aug 2007
    Switzerland, Lausanne
    If true ;-) that's a tricky one... Well done for traking this down!
    I discovered it by chance jjjj
    I was testing and I saw that every time the connection between foolcontrol and helium was lost, it was when the camera towards the auto calibrate...
    http://www.tupra.es
    @tuprastudio
  5. #5 All works again
    Hello again
    I have carried out several tests and I can confirm that:
    after deleting the sensor calibrations and performing a full automatic one again, foolcontrol already works without problem.
    http://www.tupra.es
    @tuprastudio
    Senior Member Antony Newman's Avatar
    Mar 2012
    London, UK.
    Toni,
    Can you report this to RED please.
    If you are able to help the reproduce this problem - they will be able to fix this AutoCalibrate wifi dropout issue.
    Thanks,
    AJ
