Thread: Kinefinity MAVO Edge
Page 18 of 21 FirstFirst ... 81415161718192021 LastLast
Results 171 to 180 of 201
  1. #171
    Aug 2008
    Quote Originally Posted by Misha Engel View Post
    Not sure how to evaluate the comparison table in that article since I can’t read the language. What is the color space column indicating?
    The native color space for CDNG from the format specs is CIE XYZ, essentially unrestricted by anything other than sensor and camera color science. It has to be converted to a working display color space, preferably with a mathematically correct color managed workflow in Resolve or similarly capable apps.
    Quote Originally Posted by Björn Benckert View Post
    Arri raw let you change iso, whitebalance etc, exlain the difference between that and redraw exept red raw is compressed?
    Hey no argument here...I had nothing to say about Arri Raw vs Red Raw. I was simply correcting a poster that stated ProRes Raw isn't actual raw because it doesn't have an ISO or white-balance slider. In fact ProRes Raw does have full exposure and white balance control...it just comes in a different interfase. The only new Raw format I know of that isn't 'real raw' is Braw because of the partial de-bayer. I have no opinion on better or worse or Arri Raw or any of that. Simply pointing out that ProRes Raw is a 'real' raw format.
    Aug 2011
    Here's some more ProRes Raw footage you can play around with from a Nikon Z6 and Atomos Ninja V.
    https://drive.google.com/drive/folde...MkV6rlZUPw6oXT
    Aug 2011
    Here's a in depth look at ProRes Raw
    ProRes RAW - Expectations and Reality | PART 2: DEEP ANALYSIS
    By The DP Journey
    TIME STAMPS
    01:32 Types of RAW
    02:41 What is ProRes RAW
    03:48 The meaning of RAW
    04:58 PROs: Performance
    07:14 PROs: 12bit
    07:36 10bit Vs 12bit
    09:56 PROs: Compatibility
    11:23 PROs: Selectable Log Curve
    12:12 PROs: Metadata
    13:04 PROs: File Size
    14:28 CONs: RAW Controls-WB & ISO
    17:47 CONs: Corrections
    19:24 ProRes RAW analysis
    21:29 Who is ProRes RAW for?
    Aug 2011
    Atomos Academy tutorial: Alister Chapman shooting ProRes RAW with Sony
    ATOMOS
    The first 12:47 minutes are a great tutorial about ProRes Raw, the rest is about how to set up Sony cameras to use it.
    Rand:
    Have you graded projects shot with the Mavo LF (I know you've graded footage, but projects)? Long thread, but if so, what do you think of the camera?
    There are so many great camera choices right now. Great time to be alive :-)
    Aug 2011
    Carlos,
    Unfortunately I have never graded a "long-form" project of exclusively Mavo LF file content. I like the skin tones a lot, but I've seen many videos, due to the kinefinity cameras low cost, of the camera being used with low quality vintage lenses that don't do the camera justice. Still waiting to see how the internal Prores Raw files from the upcoming Mavo Edge behave in post. I've been playing around with externally recorded Prores Raw files captured from other cameras. But, I just want to see how the internal Prores Raw files can actually be pushed and corrected in an everyday color correcting workflow.
    Jan 2008
    London UK
    Quote Originally Posted by David Rasberry View Post
    ARRI uses dual gain to increase to first stage captured bit depth (22 bit AD) for better deep shadow detail retention and noise performance, effectively increasing usable dynamic range. I don't think anyone else does this.
    Blackmagic BMCC 2.6K (OG)
    Blackmagic Pocket Cinema Camera.
    Blackmagic micro cinema camera.
    Ursa Mini 4.6K
    Ursa Mini Pro
    Ursa Mini Pro G2
    Same idea. Dual gain sensors that have a combined high bit depth (22+) to create a single 16 bit lin image. Then converted to 12bit LOG for encoding.
    JB
    John Brawley
    Cinematographer
    London UK
    www.johnbrawley.com
    Jun 2017
    Quote Originally Posted by John Brawley View Post
    Ursa Mini 4.6K
    Ursa Mini Pro
    Ursa Mini Pro G2
    JB
    BMD Ursa's have the fairchild mst4625a which are 2x11 bits https://www.fairchildimaging.com/pro...nsors/mst4625a
    The Alev III sensor is 2x14 bits https://www.onsemi.com/PowerSolution...o?article=3723
    ONsemi bought fairchild imaging a while ago.
    Senior Member Rakesh Malik's Avatar
    Apr 2013
    Seattle, WA
    It's still a dual gain design, though BMD is using more modern sensor designs than Arri is. :)
    Rakesh Malik
    Director of Photography, Colorist
    http://WinterLight.studio
    http://www.imdb.me/rakeshmalik
