Thread: Blue and red dot on output files
Page 1 of 2 12 LastLast
Results 1 to 10 of 13
  1. #1 Blue and red dot on output files
    Hey guys!
    I sometime have blue and red dots with crazy values all over my image after export from REDCINE-X.
    shot on DRAGON 6K (5K FF)
    here's my export settings
    Funny thing: I don't have them while exporting at 5K, only 2 and 4K.
    Thank you :)
    It's getting worse on some footages..
    in REDCINE-X
    *.exr exported from redcine-x and loaded in NUKE
    Mar 2011
    Toronto, ON Canada
    Try Resolve
    ___________________________
    10 frame handles
    Vimeo
    Instagram
    Aug 2011
    Julian,
    First try using a 45 "DWA Compression Level" instead of 25 and see if that helps. The default for OpenEXR is usually 45. Plus where and how are you viewing this file?
    Also, do you have the latest version of Redcine-X
    https://www.red.com/download/redcine-x-pro-win
    Or the latest Beta version.
    https://www.red.com/download/redcine-x-pro-win-beta
    And the latest Driver for you OS and Graphics Card?
    Aug 2011
    What are your Nuke Settings
    I don't use Nuke but Here are some links that may help
    http://www.nukepedia.com/written-tut...-initial-setup
    http://www.nukepedia.com/written-tut...t-lut-settings
    Introduction and Setup of an ACES Workflow (Mari, Maya/Arnold, Nuke)
    The Nuke setup starts at the 7:27 minute Mark
    ACES OCIO Configs: https://github.com/hpd/OpenColorIO-Configs
    mmColorTarget: http://www.nukepedia.com/gizmos/colour/mmcolortarget
    You can also follow one of the links here
    https://m.youtube.com/results?search_query=Aces+in+Nuke
    Dec 2014
    Sarajevo
    Do you have any image effects going on (alchemy, unsharp, hp sharpen etc)? Levels, gamma? Turn them all off, reset everything to the defaults!
    Or switch ACES (Gamut Managed) to Full Graded (IPP2 Mode) at Exp. tab.
    Bob Gundu: thanks but I need Nuke first.
    Rand thompson: Thanks for the links. I got my nuke well setup.
    I have all those crazy blue and red dots only when exporting *.exr: I tried *.dpx and it worked just fine (too bad we don't have "ACES gamut managed" with DPX.) That's really weird, I exported another footage (5k this time) without problem, what the heck is going on?
    Šabović Adis: I have no parameters checked. I only disabled the output tone map (contrast) by default. I reinstalled the latest (and beta) version of redcine-x and got the same result.
    Can someone try it on his computer please?
    Footage's here: https://drive.google.com/drive/u/1/f...kqxbflevb7PDVt
    Are you seeing artifacts of negative pixel values?
    See http://www.reduser.net/forum/showthr...=1#post1813920
    "Dream so big you can share!"
    Michael Tiemann: thanks, but checked this option didn't change anything unfortunately.
    Aug 2011
    Julian,
    I think I found your problem.
    When I exported the EXR out at the down-res resolution of 4096x2160 and brought it into an ACES workflow in Resolve, I got the same results as you did
    When I exported the EXR out at the Clips Resolution of 5120x2700 and brought it into an ACES workflow in Resolve, the 46 second clip played and looked fine
    Also, I put this in a 4096x2160 Resolve Project timeline
    Here it is at 3200 out of Redcine-X , plus noise reduction and some color correction in Resolve
