Thread: Red trade in sensor upgrade: From Dragon X to HELIUM
Results 1 to 6 of 6
  1. #1 Red trade in sensor upgrade: From Dragon X to HELIUM
    I'm a Dragon X 6K owner, and i would like to upgrade to Helium 8k, my questions is: The Helium will be the 8k 60fps version? or the standard Epic-W 8k 30fps?
    Nov 2011
    Brooklyn
    Quote Originally Posted by Roberto Leone View Post
    There is no Epic W anymore. It's just full Helium with max specs.
    Nick Morrison
    Founder, Director & Lead Creative
    // SMALL GIANT //
    smallgiant.tv
    ok thanks
    Junior Member Trenton Massey's Avatar
    Jul 2015
    Phoenix, Arizona
    It's Helium 8K 60fps. That Epic-W was a mistake. Not sure what they were thinking with that one. Everyone who was suckered into buying that camera has since upgraded. That Dragon sensor is actually a little bigger than the Helium sensor and I've shot both back to back in 6K, the Dragon footage almost looked better because it's using the entire sensor. Unless you really need 8K, I'd stick with the Dragon or move up to the Monstro personally.
    Trenton Massey
    Director of Photography, Camera Operator, Producer
    www.ambientskies.com
    trenton@ambientskies.com
    Quote Originally Posted by Trenton Massey View Post
    I don't know what you are talking about. The Helium camera uses the entire sensor just as any other offering by RED. Unless you own one, you'd come up with speculative garbage you have no clue of.
    Dec 2010
    Toronto & Vancouver
    Quote Originally Posted by Neil Abeynayake View Post
    I think you misinterpreted what hes saying, as hes actually correct; re-read what he wrote... He thinks Epic-W was a mistake and should have only been Weapon Helium/DSMC2 Helium. With Epic-W you need to window down to 6k before you get decent HFR (if memory serves EW only did 40fps at 8kWS). And in either case, Dragon 6k is actually ~1mm bigger horizontally than Helium 8k (and substantially bigger when comparing Dragon 6k to Helium cropped to 6k).
    The OP just wanted to make sure the Dragon-X to Helium upgrade was to go to DSMC2 Unified Helium and not an Epic-W (which has been discontinued for obvious reasons, which is what Trenton was referring to).
