Thread: Clip on matte box solution for rotating anamorphic lenses (LOMO, HAWK C-Series etc)
Results 1 to 4 of 4
  1. #1 Clip on matte box solution for rotating anamorphic lenses (LOMO, HAWK C-Series etc)
    Hi All
    I wanted to post something here that ive been working on for a while that I think will make peoples lives easier. Its a systme that now lets you use a clip on matte box on vintage anamorphic's where the front rotates (LOMO, TODD AO, Hawk C-Series etc)
    Hoping to make AC and DP's lives easier. You can use standard arri matte box backs, (Or bright tangerine etc) just as you would on a more modern lens. and also now no need to move motors on the rods when singing lenses as all the iris and focus gears are now in the same place relative to the mounting point. (of course you can still mount them traditionally if you chose)
    Heres a little video of it in action
    https://vimeo.com/395286742
    and meaning you can strip away all cage ad rods if you want, perfect for gimbals
    https://vimeo.com/395287125
    and the site.
    WWW.ARMACINE.COM
    Thanks guys, hope you like
    Mar 2011
    Houston TX (formerly Brooklyn NY)
    This is beautiful, and if these existed when I had my set of Lomo anamorphics....well I'd probably still own them!
    Senior Member Jacek Zakowicz's Avatar
    Jun 2008
    This a very slick design- congrats. So now there is a choice between this and the internal focusing front module 114mm that is also available for these lenses
    Jacek Zakowicz, Optitek-dot-org, jacek2@optitek.org
    Professional Broadcast and Digital Cinema Equipment
    Thanks Rob
    Here is a video of the 35mm using a standard 143 back on the lmb
    https://vimeo.com/397547373
