Thread: Help with Mimimag - Redundead - EaseUs
Results 1 to 6 of 6
  1. #1 Help with Mimimag - Redundead - EaseUs
    Junior Member
    Apr 2016
    San Jose, Costa Rica
    Hi, we have a problema and I wanted to see if one of you guys that have used Redundead can help. While our editor was downloading the material the card gave an error. He pulled back and pull in and apparently by mistake he click yes on the Time Machine question that pops up. Because suddenly what shows when we plug the card to download is a Folder with the name of the card but inside there's a folder called Backups.backupdb and inside the folder there's an Empty Folder Called MacbookPro - see image
    https://drive.google.com/file/d/1ojZ...hbOTBb7V5/view
    At this point? If thats what happens, can we get back the material?
    Anyway I Tried Redundone several times, doing it as shown in the pdf instructivos but the problem is that it keeps giving me this error Error: REDundead must be run as root ( 'sudo REDundead' for example) - check the pick
    https://drive.google.com/file/d/1Nn3...HLFbCF2C5/view
    If someone has used redundead and had the same error could you help me and see what is wrong? Thanks
    As Im trying everything possible I read about this app EaseUs and downloaded it and run a scan and got this response
    Any thoughts? have any of you experienced something like this?
    If someone can help, I can send you a basket of Costa Rican coffee and goodies :)
    Thanks!
    Senior Member Robert Hofmeyr's Avatar
    Sep 2009
    South Africa
    Try typing "sudo" before your redundead command in the terminal.
    Junior Member
    Apr 2016
    I typed sudo and it keeps me giving me the same error
    Sep 2009
    South Africa
    I can't see your images. Please post the text you are typing into the terminal.
    Sep 2009
    South Africa
    Quote Originally Posted by Miguel A. Gomez View Post
    Ah, can see that one. Not sure what the problem is, but it may be that macos formatted the mag. You could try putting it back in the camera and reformatting it (NOT secure format), then trying again.
    Junior Member
    Apr 2016
    Hello, Just to follow up and talk about the process just in case. I ended up getting the material back from an app called Restorer from Bitmart. I tried EaseUS and Redundead with no luck. But I got to say Easeus and Redundead were able to recover material from other minimags that I used doing different scenarios of formatting while trying to figure out a way. However at the end for this little problem, it was Restorer that did the trick. I paid 49 dollars so it was cheaper than expected.
    Thanks!
