Click here to go to the first RED TEAM post in this thread.   Thread: KOMODO VAXIS WIRELESS VIDEO ACCESSORY!
Page 1 of 6 12345 ... LastLast
Results 1 to 10 of 60
  1. #1 KOMODO VAXIS WIRELESS VIDEO ACCESSORY!
    Hey guys, VAXIS is releasing a custom KOMODO wireless video system called Vaxis ATOM 600 KV.
    Main Feature:
    600ft Transmission Distance
    1080p
    <0.1s delay
    SDI input
    SDI/HDMI Out
    Power pass thru
    App enabled monitoring via iOS/android (up to 4 receivers)
    Data encryption
    Comment on your thoughts of the design and what you think are must have features in the system.
    We will debut the ATOM 600 KV at NAB 2020 at booth C7915. More info to come!
    Last edited by Mike Liu; 02-27-2020 at 08:10 PM. Reason: Added additional features and photos
    Senior Member Tim Daust's Avatar
    May 2016
    Atlanta, GA
    Quote Originally Posted by Mike Liu View Post
    Main Feature:
    1080p
    <0.1s delay
    SDI input
    Power pass thru
    it would be really nice to make one that fits into the battery slots on the back and passes through to a V-Mount plate similar to the Storm 3000 Dual V-lock tx. This way we can run V-mount battery & have wireless video. not sure if that is possible or not.
    Tim Daust
    Reelmind Studios
    WEAPON HELIUM 8K S35 #6197 "Wicked"
    DSMC2 GEMINI 5K S35 #15175 "Jade"
    @TimDaust @ReelmindStudios
    Excellent news Mike!
    Looking forward to it!
    Formerly known as "nutman"
    ||| RED ONE #1333 ||| Epic-X #1003 |||
    ||| RED Hydrogen Houdini #0034 Titanium #1014 |||
    H4Vuser
    Junior Member Benjamin Jarvis's Avatar
    Aug 2017
    Texas
    Quote Originally Posted by Tim Daust View Post
    +1 to Tim's comment, but would like to see a gold mount option.
    @tim, check out the photos I just uploaded. The gold mount is a great idea!
    Jul 2013
    NYC
    Looks GREAT Mike.
    clap clap clap
    is there an internal battery powering Komodo,
    since V-mount isn’t attached?
    May 2016
    Atlanta, GA
    yep - bring it on - ill take one
    Tim Daust
    Reelmind Studios
    Senior Member Scott Balkum's Avatar
    Jan 2015
    Austin, TX
    Oh I like where this is going.....
    Red Dragon-x "Big-Skippy"
    www.imaginationx.com
    Nov 2011
    Toronto
    That's pretty cool, a few thoughts:
    -+1 Gold Mount
    -Can the SDI Out be on the camera right/AC side? If it could have two SDI out ports that would be neat.
    -I'm little worried about the antennas obstructing the built in monitor on top of the komodo or even an additional monitor like in the picture with Bay. Maybe if they came from the right side? and/or with right angle connectors?
    -AUX power out would be a great idea, to power onboard monitors and FIZ. 2x P-Tap or 2pin Lemo minimum. Probably have to put them on top? Preferably with some rubber stoppers for weather protection when not in use.
    -I could be wrong but it looks like it may extend past the bottom of Komodo? That could be a problem for using the EXT box that Jarred teased with Timecode/Genlock etc. or whatever else will be coming out form Red/3rd parties
    -it needs an onboard battery to work? (can't be fed power from camera if for example working with a small build for remote/hard mounting and powering via DC-in, perhaps it could have it's own DC in?)
    -if the camera side mount was swappable to v-mount/gold mount that would add a lot of value as this could be camera agnostic. Would probably add a bit of length/cost and i'm not sure how everyone would feel about that.
    I understand there isn't much real estate on Komodo or this module, which is/was already a bit of problem with the larger DSMC1/2 but Komodo makes it worse. Probably part of why Jarred is stressing that this isn't meant as an "A-Cam". I wouldn't mind if you had to add a bit more length to the back of the camera to accommodate power/SDI outs, as I have a feeling any build with (proper) cine glass and an onboard monitor will end up very front heavy anyway.
    Member David Groves 1's Avatar
    Oct 2016
    Los Angeles, CA
    OOOOOOH Sexy!
    Red Raven #001827
    Hydrogen One Houdini #0058
    Canon 5DMKiii
    Canon EOS R
    Rokinon Cine DS Primes
    Digital Sputniks with Pixel Mapping, Hives, Quasars, Litepanels Gemini, Arri 750s
    Dji Ronin, Cloud Mount, Motion Control, Dana Dolly
    https://www.instagram.com/galacticowboy/
    https://www.twitch.tv/galacticowboy
Tags for this Thread
View Tag Cloud
