Thread: 1.8x Anamorphic support?
Results 1 to 7 of 7
  1. #1 1.8x Anamorphic support?
    Senior Member Josiah Duncan's Avatar
    Jan 2016
    Indianapolis, IN
    Shooting more and more anamorphic nowadays, and gearing up to do some tests in the next week or two. With different ratios coming out of Cooke's high end, when can we expect a 1.8x mode supported? I don't care as much about 1.5x but I imagine other people do so it wouldn't hurt, the more lenses we can use practically in cam the better. Is this coming with a new firmware update any time soon? 1.8x support at 4/3 is what it looks like I may be needing this year.
    Edit: Would also really like 1.65 ratio - been working with some different optics recently and the more options the better, 1.6 is pretty difficult to deal with in cam right now.
    Senior Member Michael Lindsay's Avatar
    London UK
    1.65x support would be good too.... I am assuming DXL2 has it already?
    Senior Member Mathias Erichsen's Avatar
    Nov 2008
    Oslo, Norway
    I’m hoping for 1.8x and 1.5x support too :)
    Senior Member Zack Birlew's Avatar
    California and Las Vegas
    I wish that anamorphic lens manufacturers would stick with 1.33x or 2x to keep things simple but admittedly with digital these days it's just a touchscreen flick on the menu screen to crop, stretch, and squeeze the image as needed so if the middle-range lens ratios can work then everybody should start programming those in at this point if anamorphic support is in the camera already. If not, then you're going to have to try looking around at the external monitors on the market and see if any of them have squeeze modes that work, there's remarkably a lot more anamorphic support than expected on my cheap Feelworld LCD.
    Senior Member Tom Gleeson's Avatar
    Nov 2007
    Sydney
    Josiah,
    This request has been made to Red for a while now. I asked Red about it last year for a project and got a "Well maybe. We are looking at it but no timetable..." With other top line cameras supporting the 1.8x squeeze Red should step up. Make your feelings known to Red. It must be harder than it would seem but nothing will happen if Red doesn't get the feed back.
    Tom Gleeson
    Senior Member Aaron Lochert's Avatar
    Oct 2013
    Tucson, AZ
    Quote Originally Posted by Zack Birlew View Post
    It'd be nice, but I think the lens manufacturers are sort of always following the sensor designers. As the intended goal of anamorphic has always been to maximize the surface area of recording and increase captured detail versus grain. It seems with the 1.65x's and 1.8x's, that concept is still holding true.
    I think as the world moves toward 8K and beyond with cleaner and cleaner sensors, they're going to care less about this sort of thing and we'll be able to choose anamorphic for purely aesthetic reasons because we can afford to throw so much resolution away at capture. And I think when that happens we'll just settle back at 2X anamorphic since it has all of the "look" we've been conditioned to love.
    Makes me wonder, though, has any lens designer ever tested wider than 2X squeeze? I was thinking 1.33x always seemed like a cop out since you don't really bring along much of the anamorphic look and feel. What if we turned the camera bodies 90 degrees and shot on a 4X anamorphic? You'd get a 2.1:1 ratio on a red sensor, 2.25:1 on a 16:9 sensor or 2.6:1 on an Arri open gate. Would the anamorphic stretch effect be insane looking? Would the lenses be stupid hard to design?
    Jan 2016
    Indianapolis, IN
    Quote Originally Posted by Michael Lindsay View Post
    I agree. I've been working with some weird optics recently and would also love to add 1.65/1.66 to my list. It's right in between the supported squeeze ratios so there's no great way to monitor it in camera.
