Thread: MINILF-MONSTRO thoughts ;)
Page 4 of 13 FirstFirst 12345678 ... LastLast
Results 31 to 40 of 122
  1. #31
    Senior Member luigivaltulini's Avatar
    Oct 2009
    Switzerland- LUGANO
    Quote Originally Posted by rand thompson View Post
    .Arx single frames work fine.
    added first page thread;)
    https://drive.google.com/open?id=1lA...gFdfW5065lm_0G
    Grading Suite Davinci Resolve, Rental RED Digital camera.
    MONSTRO 8k CF #831 "BLACK PEARL" , EPIC-W GEMINI # "DAFNE".
    ARRI ALEXA EV , ALEXA MINI LF "ROZI"
    SITE
    www.cine5k.ch
    Oct 2009
    Switzerland- LUGANO
    This is very strange..
    The traffic lights on RED showed no clipping up to f5.6 !!
    While on Alexa Mini Lf the tools showed me the clipping limit at T8.
    I shot on REd T8 / 11/16 and with surprise the RED bulb shows some imperfections on the outline !!! ... I had to go down to T16 to get it all back then - 2 stops.
    Download link :
    https://drive.google.com/open?id=1Qy...FvWkyF2HZ4pSUB
    [IMG]BULBO by luigi valtulini, su Flickr[/IMG]
    SITE
    www.cine5k.ch
    Aug 2011
    Quote Originally Posted by luigivaltulini View Post
    Perfect!
    Quote Originally Posted by Björn Benckert View Post
    To me more interesting to compare cameras when both are exposed correctly, like if they both have the highlight a stop under clip or such.
    "A stop under clip" doesn't show DR handling relation between cameras.
    Same exposure and paralel ramping stops does.
    Analog > Apollo wooden handgrip http://omeneo.com
    Digital > Primers - professional image transformation tools http://omeneo.com/primers
    imdb
    "Como delfines en el fondo del oceano
    volamos por el universo incentivados por la esperanza"
    "L'esperanza", Sven Väth
    "It's a poor sort of memory that only works backwards"
    Jung/ Carol
    Aug 2011
    Just can't get that same look as Monstro.
    Arri .ARX file
    Arri .ARX File
    Here's one you can try for fun.
    When exposing w/ Monstro versus the LF, in particular in these side by side sort of setups instead of rating at ISO 800, try 1280 and 1600. Even 2000 is worth a stab w/ the Standard OLPF you are using.
    All things being equal that will give you what you want in the highlights and still be cleaner in the shadows when finishing to 4K and 2K.
    This is the old "Dragon trick" many DPs started to utilize in the DSCM Dragon days because they figured out it was a cleaner image and once discovering metering and exposure in relationship to ISO Rating provided more information for the highlights, they ran with it. Which is why some films were shot at higher than ISO 800.
    phfx.com IMDB
    PHFX | tools
    Data Sheets and Notes:
    Red Weapon/DSMC2
    Red Dragon
    Aug 2011
    Thanks Phil for the Advice! I was leaving everything at ISO 800 and just using custom luminance curves. I'll try a higher ISO .
    It's more about how the image is exposed in camera.
    A better/easier way to think of it if you are exposing correctly at 18% Gray
    Try:
    - Alexa LF at ISO 800 at whatever T Stop
    - RED Monstro 8K VV at ISO 1600 w/ 0.3 ND at the same T Stop
    So much of this is really about where information lands and exposure logic.
    phfx.com IMDB
    PHFX | tools
    Red Weapon/DSMC2
    Red Dragon
    Senior Member Jacobo Martinez's Avatar
    Jul 2013
    Nicaragua
    @Rand, I think Phil means higher ISO at the moment you expose for the scene, when you decide how much light will hit the sensor.
    Edit: sorry, didn't see Phil's response.
    Aug 2011
    Jacob,
    Yeah, I always grade red footage at 800 ISO and use luminance curve/contrast-pivot/and Log shadow to give it contrast. I actually thought for minute that Phil meant after the fact. I'm straighten out now...hahaha.
