Thread: Broken pin - module
Results 1 to 7 of 7
  1. #1 Broken pin - module
    Senior Member Patrick Tresch's Avatar
    Aug 2007
    Switzerland, Lausanne
    Hello,
    I would like to know if someone had such a problem on a module? My pins got broken but I don't know what are the causes?
    Is it due to humidity? Shortcut? I don't see what could cause this? It's probably power that go throug those pins as the camera wasn't responding when I pressed the power button.
    The module was allways sitting on the brain and no particular event broke it. I would like to prevent this to happen again.
    I've changed the module and the camera works again.
    Any inputs are wellcome.
    Patrick
    PS: I've open a support ticket and sent my logfiles.
    PS2: I've tried to moove them but they stay recessed
    Senior Member Tom Gleeson's Avatar
    Nov 2007
    Sydney
    Patrick,
    Definitely wait for a reply from Red Support but there is a possibility that some electrical contact spray may lubricate the pins enough for the spring to push the contacts out? I would be very careful with any physical force as any deformation of the pin would be a bummer. Unsure why this would happen?
    Tom Gleeson
    Mar 2011
    Toronto, ON Canada
    The is the weakest design of DSMC2. Its too easy to misalign and damage it. I hope it improves in DSMC3.
    ___________________________
    10 frame handles
    Vimeo
    Instagram
    Aug 2007
    Quote Originally Posted by Bob Gundu View Post
    But this module was on the brain since day 1, 3 years ago. I wonder if I had a power draw problem. Still sorting this out with the (very proactive) Red support.
    Pat
    Senior Member Antony Newman's Avatar
    Mar 2012
    London, UK.
    Guessing that when the module was pushed in from behind, the bottom right side of the module made contact first, then the bottom left - then with a slight angle (5-10 degrees from vertical) it was pushed forward with enough force to bent the pins (and pushed some in) before the top left and top right sides were pushed in and made full contact with the back of the brain.
    If exposed pins are part of the next design, and insertion when misaligned (or misangle) could cause damage - this is likely something RED should design-out of the next body.
    AJ
    Quote Originally Posted by Patrick Tresch View Post
    Pat
    Are the pegs pushed in or broken of? Looks like they are pushed in and stuck there, no? Possibly just use some contact cleaning / lubing fluid like 5:56 or such to make em come out.
    Or, maybe it voids the warranty. But cant you screw it a part and peak inside. See if its burnt or such.
    To me it looks like poor connection that caused heat and erosion that made the peg stuck in there. But yes that me guessing from looking at that picture.
    Björn Benckert
    +46855524900 www.syndicate.se/axis
    VFX / Flame / Motion capture / Monstro
    Aug 2007
    The pins are pushed in. They come out when I use canned air but drop in again when slightly pushed.
    Like there wouldn't be any spring pushing them out. I used some WD40 drop to try to wake the spring but nothing happens...
    The board with the pins is soldered on the PCB board.
    I will send it in for repair or replacement. But still trying to figure out if it is corrosion (nomal use) or shortcut (abnormal use).
    Pat
