Click here to go to the first RED TEAM post in this thread.   Thread: RedCine-X constantly crashing when opening clips
Page 1 of 2 12 LastLast
Results 1 to 10 of 11
  1. #1 RedCine-X constantly crashing when opening clips
    Always when i'm opening RedCine-X and try to open a clip it just crashes/closes the application.
    Only happens since the actual release 51.47074.
    I'm on Windows 10. Anybody noticed this issue?
    Thanks!
    Aug 2011
    Tim,
    What graphics card do you have installed in your computer? And what was the resolution of the clip you were trying to open?
    GPU: GeForce GTX 770, driver up to date
    Windows 10 Version 1809 (Build 17763.737)
    Dragon 6K and also Helium 8K footage.
    Aug 2011
    Tim
    Nvidia Drivers
    https://www.geforce.com/drivers
    So the Nvidia Geforce GTX driver you have is Version 436.02 as of August 20 2019?
    And I believe the most current version of Windows 10 was 1903 which I think initially had some audio problems, but I believe they were fixed. I know 1809 was all that was required for this version of Redcine-X
    Also , does your system meet these requirements for Redcine-X Version 51.0.47074?
    REDCINE-X Professional RELEASE CANDIDATE Build V51.0.47074 – Windows (64-Bit) Build
    SYSTEM REQUIREMENTS
    64-bit Windows Vista to Windows 10 (version 1809)
    1GB hard drive space
    8GB RAM (recommended)
    2GB GPU Video RAM (when using GPU acceleration)
    Windows 4GB GPU Video RAM (when using GPU R3D decompression)
    Aug 2011
    Tim,
    if nothing else works, you might want to send a "Log Report" to Red so they can see what is going on.
    1) Enable "Verbose Logging". This, According to the "Redcine-X Pro Operations Manual"
    "Adds more information to log files. Only select Verbose Logging if you need extensive log files for Support. Enabling Verbose Logging may slow down your computer performance. "
    2) Go to the "Help" Tab and "Show Log File..". This will show a list of the most recent Log files that have been created. Copy the last one, in my case was 5/22/2019, which I don't have selected in this screengrab
    3) Send a Zip file of your System. Go to the "Help" Tab and "Show System Information.." and save it somewhere .
    You can also, After you enable "Verbose Logging", manually "Save Report" after the incident happens or just whenever. Go to the "Help" Tab and "Save Report"
    Quote Originally Posted by Tim Hupfauer View Post
    Hi Tim, I have no idea why you are crashing, but that GPU is pretty on the low side of things to be able to accomplish much. And since RCX relies heavily on the GPU I'd suggest at a minimum go to a GPU with 4GB of RAM. I would truthfully really suggest 8GB. Maybe grab a used 1080, if you want to go hog wild go for the newer RTX stuff.
    All of my systems use Nvidia GPUs and I don't have any of the issues you're experiencing, I personally think that will help. Particularly with the 6K and 8K material.
    phfx.com IMDB
    PHFX | tools
    2X RED Monstro 8K VV Bodies, 1X RED Komodo, and a lot of things to use with them.
    Data Sheets and Notes:
    Red Weapon/DSMC2
    Red Dragon
    Thanks Phil, i'm aware that the specs are pretty low-end, but it never used to be a problem to load 6K/8K clips before (despite the bad playback), so i'm wondering ...
    Senior Member Dmitry Burenok's Avatar
    Nov 2011
    Vancouver
    Same troubles here, RED Cine-X crashing all the time, RED PLAYER APP works fine - even Rocket_X decoding works as intended. Is anyone even care about RED CINE X anymore? Feels like no actual support being provided...
    http://bigwavesproductions.com
    docrender@gmail.com
    Scarlet X #1258
    EPIC X #3795
    EPIC X DRAGON #08501
    LEICA R, XEEN, Canon
    Nov 2011
    Vancouver
    OK here an easy explanation - RCX 51 still RELEASE CANDIDATE once I roll back into RCX50 (current PRO official release) everything becomes normal - Rocket X works 6/8 K files playback/decode real time no problem at all. Guess further complains about RCX51 wont make any sense until we got official release. Easy as that.
    docrender@gmail.com
    Scarlet X #1258
    EPIC X #3795
  10.   Click here to go to the next RED TEAM post in this thread.
  #10
    RED TEAM Stacey Spears's Avatar
    Sep 2007
    Sammamish, WA
    Quote Originally Posted by Dmitry Burenok View Post
    That is a typo on the web page, it is the release version.
Tags for this Thread
View Tag Cloud
