Click here to go to the first RED TEAM post in this thread.   Thread: ISO 800 LL?
Page 1 of 2 12 LastLast
Results 1 to 10 of 11
  1. #1 ISO 800 LL?
    Junior Member
    Jan 2016
    Chicago
    Recently worked with another Gemini owner who was shooting 800LL. I canít for the life of me figure out how to do this. Can someone help? Thanks in advance.
  2.   Click here to go to the next RED TEAM post in this thread.
  #2
    When you select the ISO, you can edit the list of ISOs that appear in that list. Just add ISO800 and you're good.
    Graeme
    www.red.com - 8k Digital Cinema Camera
    Science enables stories. Stories drive science
    IPP2, Image Processing, Colour Science and Demosaic Algorithms
    Junior Member
    Jan 2016
    Chicago
    Thanks much!
    Jul 2018
    Boiling Springs, PA
    Thanks no idea you could do this.
    R3D DSMC2 GEMINI
    Canon CN-E Primes
    Senior Member Christoffer Glans's Avatar
    Jun 2007
    Stockholm, Sweden
    But, isn't the point that the DR is maximized at a higher ISO in LL mode? Meaning, you lower the effective DR if you go under in LL.
    "Using any digital cinema camera today is like sending your 35mm rolls to a standard lab. -Using a Red is like owning a dark room."
    Red Weapon 6K #00600
    Junior Member
    Jan 2016
    Chicago
    I’m about to shoot a short that’s at night. I’m going to do some tests, but The majority of the short takes place outside (going to emulate the moon) and a dark bar. There really won’t be too many highlights, but there will lots of shadows. I want to rate my sensor lower to keep my blacks cleaner.
  7.   Click here to go to the next RED TEAM post in this thread.
  #7
    Within a mode, DR is constant regardless of ISO. When you change ISO you're just changing the distribution of below and above stops.
    Graeme
    Junior Member
    Jan 2016
    Chicago
    @Graeme, then is my thought process correct in rating the sensor to put more DR in the shadows?
  9.   This is the last RED TEAM post in this thread.   #9
    Lower the ISO, the more DR in the shadows (vs highlights). Higher the ISO you build in more highlight protection. So using LL mode will start with the sensor giving you lower noise in the shadows, so just use as little ISO gain as necessary to make the key elements of your low-light scene as bright as you need to see them.
    Graeme
    Junior Member
    Jan 2016
    Chicago
    Awesome. Thanks!
