Thread: Sony VENICE and RED Monstro Anamorphic in 4K HLG HDR right out from cameras
Page 1 of 3 123 LastLast
Results 1 to 10 of 24
  1. #1 Sony VENICE and RED Monstro Anamorphic in 4K HLG HDR right out from cameras
    Aug 2011
    By Sittipong Kongtong
    I had a test with 2 high end camera, Sony VENICE and RED Monstro in anmorphic mode. I used 2x anamorphic lens; Cooke, Master Anamorphic, Kowa, LOMO. All lens has beuatiful color for both cameras.
    I tested at Life Boat, a camera and lens rental house in Bangkok.
    I export this file in 4K 25p DCI Scope DNxHQX 12bit for Youtube.
    You can see it on any OLED HLG HDR devices.
    Senior Member Christoffer Glans's Avatar
    Jun 2007
    Stockholm, Sweden
    Why is the Monstro so unbalanced in its tint?
    "Using any digital cinema camera today is like sending your 35mm rolls to a standard lab. -Using a Red is like owning a dark room."
    Red Weapon 6K #00600
    Yes, when white walls are green you are doing it wrong some how. I have a difficulty to believe both cameras are at equal kelvins and tint. And even if so. Why make a test where one has the colors clearly pushed out of balance.
    Björn Benckert
    +46855524900 www.syndicate.se
    Flame / VFX / Motion capture / Monstro
    Aug 2011
    From looking at the clapboard he presented for each camera at the beginning of the shoots, he did use a White Balance of 5500 for each camera. It seems he is unaware of the Tint required to better white balance the monstro or chose deliberately not to use it for this test.
    Edit,
    The Venice seems more blue than it probably should as well. So I'm sure there are some Sony Venice owners who will probably take issue with this test as well. So I believe neither camera is truly "White" Balanced.
    Quote Originally Posted by rand thompson View Post
    Edit,
    I find cameras to be just as monitors, they can drift over time and / or loose their zero for calibration. But and as the cameras captures raw a gray card balancing would be a good start I think. But possibly they did not compare colors but other things.
    Björn Benckert
    Aug 2011
    Bjorn,
    Yeah, They probably just thought it was easier for them to just set the Kelvin the Same and just go from there. They do say that no grading was done to the images.
    here is my attempt to show how the Venice and the Monstro both could have been corrected to atleast fix the White Balance of each in this test. And yeah! I know they are jpeg images that I graded you can tell by the shitty banding in the image.
    Venice
    Monstro
    Senior Member Chris McKechnie's Avatar
    Mar 2011
    Dallas, TX
    Gosh....I really really wish RED would focus on color accuracy as opposed to resolution. I feel that the MX & Dragon sensors were much more accurate than any of the latest RED tech in terms of color. Productions care about the post workflow, and amount of work to get the image looking great, and with RED, it just takes more to get it there, where it didn't used to be that way with my tried and trusted MX sensor. That thing is a beast in terms of color, reliability, etc. I still love RED, but I think they need to hit it out of park with a DSMC 3 model that shoots 4K, but is more focused on producing amazing color as opposed to just increasing the K's. Just my opinion as I've seen RED progress/change through the years.
    Chris McKechnie
    Director of Photography
    Email - redepicguy@gmail.com
    Reel - https://vimeo.com/314919326
    Nov 2011
    Brooklyn
    Edit,
    Yeah properly white balancing with offsets in camera is a discipline that rarely happens - esp in cam tests.
    Looks like they are just eyeballing it
    Nick Morrison
    Founder, Director & Lead Creative
    // SMALL GIANT //
    smallgiant.tv
    Nov 2011
    Brooklyn
    Quote Originally Posted by Christoffer Glans View Post
    Nothing to do with the camera, they clearly eye-ball balanced to the Sony and plugged in the same values to the Monstro.
    Diff cameras almost never match...so...
    Nick Morrison
    // SMALL GIANT //
    smallgiant.tv
    Senior Member Patrick Tresch's Avatar
    Aug 2007
    Switzerland, Lausanne
    Quote Originally Posted by Chris McKechnie View Post
    Don’t take this as a color test. I never had a color issue with Red (appart from some yellow peaks you can easily turn down). I love the 6k resolution my Dragon gives me. I would never trade it for a 3.2k lowres bayer sensor.
