Thread: Battery Question for Gemini Owners
Page 1 of 2 12 LastLast
Results 1 to 10 of 13
  1. #1 Battery Question for Gemini Owners
    Junior Member
    Mar 2018
    Chicago
    Hey guys,
    I am ordering my Gemini this week and wanted to ask yall about the batteries and hotswap adapter I am looking at. I heard the gemini could be finicky about batteries the other day, so I was just curious if anyone had any experience with any of these items. They are Anton Bauer Dionic XT batteries and a Core SWX V-mount hotswap plate. Any thoughts are greatly appreciated!
    https://www.bhphotovideo.com/c/produ..._Hot_Swap.html
    https://www.bhphotovideo.com/c/produ...m_battery.html
    https://www.bhphotovideo.com/c/produ...t_battery.html
    Oct 2007
    Baltimore
    I haven't noticed the gemini being weird about batts, but I would stay well clear of v-locks. I mean, if there is a gun to your head and you have to use v-locks, AB v-locks are probably the way to go, but still ;-)
    Nick
    Junior Member
    Mar 2018
    Chicago
    Quote Originally Posted by Nick Gardner View Post
    Nick
    Yeah... I've heard some naysayers on the vlock. But it seems like v-locks are more widely available and come standard on the Red Production Module, so I'm just rolling with it with my fingers crossed...
    Oct 2007
    Baltimore
    Your funeral. Good luck!
    Junior Member
    Mar 2018
    Chicago
    Well, I am also going to have a MixPre 6 mounted on a cheese plate right behind the battery setup, so hopefully that will protect it from too much jostling. Although you are making me question it again. I completely switched out my cart to go v-mount the other day and now you're making me revisit this nonsense! Thanks a lot. Haha
    Senior Member William Long's Avatar
    Dec 2008
    Sweden & France
    Used V-locks for years in extremely rough conditions and they have never been a problem.
    Senior Member Tom Hamilton's Avatar
    May 2009
    Port Orange
    Seconded, have used Pag V-locks in underwater housings for years, in current and surge, on violently pitching/rolling boats, not a single problem.
    Dragon 6K 'Red Sea'
    Gates Deep Weapon/Dragon
    Hollis PRISM2
    FAA 333 UAS Aerial Cinematography 4K RAW
    Red Sea Pictures
    Junior Member
    May 2018
    I’ve been using CoreSWX V-Lock Hypercore 9 Mini RED for a year with GENINI. No issues. I like the LCD display, which shows remaining runtime while in use and remaining charge time while charging. With the 7-inch touch and V-lock expander IO I get about 1:50 (almost 2 hours) runtime on one battery.
    This battery also has a 2000 cycle count rating, which if accurate, should mean that it will retain its original charge capacity 2-4X longer than most batteries, which are usually rated at 500 or fewer charge cycles. So you won’t have to buy new batteries as soon.
    My one wish is that the USB port supply higher current for connected accessories. It wasn’t enough power to run a Sound Devices MixPre3. The RED V-lock expander IO’s USB port doesn’t provide enough power either.
    Senior Member william howell's Avatar
    Mar 2013
    Pensacola Florida
    V-mount batteries are fine. I’m quite sure there are benefits to using AB batteries, but.. honestly, there are so many pieces of gear that you can power with v-mount batteries that using them simplifies your entire workflow. We use Blueshape and CoreSWX batteries, so can’t answer your questions on the Anton vmount batteries... also.. we’re using the red v-lock I/o module...
    On our DSMC1 cameras we used aftermarket vmount plates (wooden camera) and those never felt super secure. There were a few instances where the vmount battery came right off for no apparent reason..
    The RED Vmount module feels rock solid, and seems like it has a death grip on the batteries once you slide them on.
    William Howell
    Senior Creative and Multimedia Producer
    Florida Institute for Human and Machine Cognition
    www.ihmc.us
    https://sports.vice.com/en_uk/articl...ics-walk-again
    Nov 2011
    Brooklyn
    Quote Originally Posted by Rob Gregory View Post
    RED cameras perform much better with high quality batteries. Trust me on this.
    DO NOT BUY CHEAP BATTERIES. DON'T BUY THEM USED.
    Get AB, Blueshape, etc.
    Some cameras like Sony FS7s can tolerate really shitty batteries. But REDS will shut down if they sense that the voltage is irregular (cheap batteries do that).
    This is big mistake folks make.
    TRUST ME. Invest in great batteries. Whether they are AB or Vmount is secondary. Just make sure they are 1st Class quality wise.
    Nick Morrison
    Founder, Director & Lead Creative
    // SMALL GIANT //
    smallgiant.tv
Tags for this Thread
View Tag Cloud
