Thread: Correct workflow for R3D files using REDCINE-X Pro build 50
Results 1 to 6 of 6
  1. #1 Correct workflow for R3D files using REDCINE-X Pro build 50
    I am currently student of Ukrainian Film School and first tie shooting my project on Red Epic Mysterium X camera in RedRaw and i want to know the correct workflow from the importing offloaded clips into the RedCine-Z pro till the Importing files that director approved as a good take into DaVinci Resolve 15. Could you help me with that set by step instructions?
    Thank you.
    My advice would be let him pic this takes in resolve...
    But if you want to do it in RCXP do this.
    Start program.
    Make sure you are in right color space etc. IPP2 preferably.
    Locate your footage and drag it into a bin.
    Let your DP do his settings, whitbalance, iso, luts etc. (difficult to quickly explain but you can do primary grades in rCXP and save them, copy them from clip to clip etc.)
    Then the DP can sit and look trough his footage and set primary colors if wanted and the clips his interested of he can drag down to the timeline. When his happy you export a XML.
    Then you import that XML to resolve, all the metadata he added should come along.
    Björn Benckert
    +46855524900 www.syndicate.se
    Flame / VFX / Motion capture / Monstro
    Quote Originally Posted by Björn Benckert View Post
    Start program.
    How to add metadata to XML file that comes from RedCine-X Pro to DaVinci will all the corrections that DP made with color science appear in DaVinci?
    And the camera doesn't work in IPP2 cause its an old Red Epic Mysterium X - with a legacy pipeline.
    Aug 2011
    Iaroslav,
    Here is an Example Workflow.
    In Redcine-X choose these settings in "Preferences" use "CTRL + ," to get to this menu. I'm using the newest 5.1 version , if you are using an earlier version , "Image Pipeline" and "Monitoring Out" will be located under the "Image Pipeline"Tab
    Here is the Sample Image already graded in Redcine-X
    Here are the settings in Redcine-X.
    It uses a 400 ISO, 3200 Temp and a Creative Lut called "Woman Next to Candle _3" which I made
    It uses these "CDL" Corrections and a "High Con/ Very Soft" "Output Tone Map" and "Highlight Roll-Off"
    Inside of Resolve we have to make these settings for the reasons mentioned.
    Use "Shift + 9" to go to the "Project settings" to get to these settings
    The first screengrab below can be found under the "Color Management" tab in the "Project Settings"
    Redcine-X
    Resolve
    Export
    For Export you can use whatever codec you need, I used these settings on a Windows Machine.
    If You chose a lower quality than "Full Res. Premium" in the "Decode Quality" pulldown Menu for better Playback or Editing in your NLE, Choose "Force Sizing To Highest Quality" "Force Debayer To Highest Quality" will export your file back at a high quality.
    It would be best to use "Full Res. Premium" at the Export stage of your project but if your computer can't handle it use the settings above.
    Two Big Caveats to this workflow
    Make sure you complete the Davinci Resolve Project after initiating it because if you close it and open the Davinci Resolve project back up again, It might not reconnect to all of the settings in Redcine-X. I don't know if this is a Resolve problem or a Redcine-X problem.
    Second,
    If you try to change a "Camera Raw" setting in Resolve, it will kick out the settings from Redcine-X and use the default from the "Red" Raw Project settings.
    I wanted to change the "Camera Raw" ISO so I changed "Decode Using" from "Project" to "Clip" and got these results. You will have to use the "Primary" grading tools and not "Camera Raw"
    Quote Originally Posted by rand thompson View Post
    Iaroslav,
    Redcine-X
    Resolve
    Second,
    Thanks a lot for your explanation, so deep explanation. ut i am working with an old Red Epic Mysterium X - and it has no IPP2 cause the camera not DSMC2 and i have just Legasy Pipeline is that ok and i can change it to IPP2 during the exporting files to RedCine-X Pro? Or i need to use a different workflow?
    Aug 2011
    Laroslav,
    The best thing about IPP2 is that in post it works with all Red cameras from the Red One to the newest DSMC2 cameras. You can't, as you said, use it in- camera in DSMC1 cams and in some DSMC2 cameras but you can use the IPP2 workflow pipeline in Redcine-X and in some other 3rd party applications like Davinci Resolve.
Tags for this Thread
View Tag Cloud
