Thread: Beachtek DXA-RED
Page 1 of 3 123 LastLast
Results 1 to 10 of 21
  1. #1 Beachtek DXA-RED
    Junior Member
    May 2018
    Hello,
    I've just seen this new compact dual XLR module for the red with phantom power. It seems to be really interesting and not to expensive $500. Has anyone ever tested it ?
    regards
    https://beachtek.com/product/dxa-red
    Deleted by me....I was wrongly commenting on the Beachtek Alexa module, not this new gizmo.
    "Dream so big you can share!"
    Senior Member Michael Lindsay's Avatar
    London UK
    Nice size... we use this instead http://www.filmtontechnik.de/en/prod...ch/dslr-mixer/ which is the same weight
    the 1st test I'd need to see is to feed the box power from the same soure as the camera...
    the 2nd test I'd need to see is to feed the box the output from a Audo RX powered by the same source as the camera...
    Senior Member David Callahan's Avatar
    Jan 2008
    Oklahoma City, OK
    That looks interesting! I've looked for a good solution and never came across the Beachtek.
    David Callahan
    Resolute Visuals
    www.resolutevisuals.tv
    Mar 2011
    Toronto, ON Canada
    Mine arrives today. I'll let you guys know.
    ___________________________
    10 frame handles
    Vimeo
    Instagram
    Nov 2011
    Brooklyn
    A Mix-Pre 3 doesn't look that much bigger - or am I wrong?
    Nick Morrison
    Founder, Director & Lead Creative
    // SMALL GIANT //
    smallgiant.tv
    Senior Member Patrick Tresch's Avatar
    Aug 2007
    Switzerland, Lausanne
    For top notch sound you have the Sonosax M2D2. It's a solution for DSLR cameras like Sony A7 or DSMC2 but can also be hooked to a Smartphone used as recorder. Internal batteries for 4 hours independent recording with 2x 48v or external power.
    https://www.sonosax.ch/product/sx-m2d2/
    Available in june I've heard.
    Pat
    Mar 2011
    Toronto, ON Canada
    Quote Originally Posted by Nick Morrison View Post
    Way smaller.
    10 frame handles
    Vimeo
    Instagram
    Senior Member Christopher S Johnson's Avatar
    May 2017
    Los Angeles, CA
    How are you attaching it?
    Mar 2011
    Toronto, ON Canada
    Quote Originally Posted by Christopher S Johnson View Post
    The default is a good option. Especially if you have a cheese plate on the side plate. But I have another that works pretty good that I'll be showing shortly.
    BTW, the sounds quality is very good.
    https://www.instagram.com/p/BxlBOXEFFQJ/
    10 frame handles
    Vimeo
    Instagram
