Thread: Hazer and Fog Machine Safety
Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
  1. #21
    Dec 2010
    Toronto & Vancouver
    Quote Originally Posted by Steve Sherrick View Post
    Perhaps the Rosco is SAG approved?
    I can't find the newletter on his site anywhere, so the info is only in the email sent out (I can forward it if you want)... This is what it says:
    "One tool. My go to smoke/diffusion is the DF-50 by Reel EFX. This is a fairly inexpensive machine and can smoke a very large area. It looks small, but it packs a wallop. This hangs for hours and gives you that consistent level. This is mineral oil, and SAG contracts do not permit this smoke.
    The Rosco 1500 has been approved by SAG to use. The problem with this smoke is that it doesn’t hang, which requires you to use 10 times the quantity. Go figure. But it has been deemed safe."
    Hope that helps.
    REDuser Sponsor Andy Jarosz's Avatar
    May 2009
    Chicago
    Double check with your network/studio as well. I was on a show earlier this year and they attached a list of network approved approved fog/haze fluids to literally every email.
    Steve, check out the Ultratec Radiance. It uses a slightly different formulation of fluid that I find hangs around longer. Most water based hazers just use a lower refractive index version of fog fluid, with the idea that you'll be running the machine continuously to maintain the level.
    MadlyFX Special Effects
    Chicago, IL
    IMDb
    andy@madlyfx.com
    So SAG in the past few years has joined with some lawyers to require testing of smoke levels in each set prior to filming. The studio hires an outside testing company who comes to the particular location/set and you add smoke while they take readings with a device. When the DP says this is the level I will never exceed they note the reading. It costs production some more money but it is the new rule. I have never exceeded 2% of the allowable amount.
    Basically if you do not do this and don't post the results any SAG actor does not have to be on set legally. Also this applies to children and animals. You CANNOT ever use smoke with birds but I just did a lot of smoke work on a Paramount film in NYC with a child star and animals and with the testing all was accepted.
    Kinda a pain from a schedule and money standpoint but the major studios are accepting this additional cost.
    Senior Member Joel Arvidsson's Avatar
    Nov 2008
    Sweden
    Any advice on a budget hazer that is quite small in size, dont make a mess on set and is considered safe for actors. Anybody that have any experince using Rosco Mini -V Fog Machine or similar? or do you recommend a waterbased hazer. In that case why? pro cons.
    Joel
    Epic #06696
    Epic-W #004069
    May 2009
    Chicago
    Quote Originally Posted by Joel Arvidsson View Post
    Joel
    Hey Joel,
    If you want a small, portable, affordable hazer, look no further than an Antari Z-350. A lot of FX friends are reaching for it as default now, as it performs well in most situations (indoors, on stage) and is far easier to lug around than larger units.
    Chicago, IL
    IMDb
    andy@madlyfx.com
    Nov 2008
    Sweden
    Thanks Andy I will read and view videos about it. I even found a local dealer wich sells them.
    Epic #06696
    Epic-W #004069
Tags for this Thread
View Tag Cloud
