Thread: tracking down the compression ratio
Results 1 to 6 of 6
  1. #1 tracking down the compression ratio
    Heaven forbid, I noticed my compression ratio in 5k had inadvertently been changed from 8:1 to 14:1 ! Not sure if this is an issue, but I was keen to work out when this menu change occurred with previously dowloaded cards. Is this possible, as when I bring shots into Premiere Pro and look through the metadata I can't find anything that indicates the compression ratio ?
    Download and install REDCINE-X PRO. It's free.
    Browse to your clips, right click (option click MacOS), and select Metadata.
    You will see all the embedded information including your REDCODE RAW Compression Ratio.
    phfx.com IMDB
    PHFX | tools
    Data Sheets and Notes:
    Red Weapon/DSMC2
    Red Dragon
    Ok great thanks Phil, I had the RedCine X pro downloaded from before, so was easy :) I'm hoping these couple of cards with the 14:1 compression will be acceptable to the broadcasters .... ?
    Senior Member AndreasOberg's Avatar
    Oct 2011
    I would think it should be fine Trevor. Should still be better than prores.
    Andreas
    www.ObergWildlife.com- Natural History Filmmaking
    www.WildlifeRescueMovie.com- Saving the animals of the Rainforest!
    CF Weapon Helium 8K Strummer Bright Tangerine, Inspire 2 X7, OConnor 2560, Canon 50-1000mm
    Many thanks for the assurance Andreas, was only half a card on closer inspection, the previous two cards were mainly 10:1 which then dropped to 12:1 for 96fps... hopefully it will pass :) I'lll be more on the ball now with checking the compression menu. I can only think I changed it when quickly diving in and out of the time lapse menu and pressed the wrong thing...
    Quote Originally Posted by AndreasOberg View Post
    Andreas
    "Better" is a relative term. :)
    Technically it is much more compressed and compression reduces image quality.
    http://i68.tinypic.com/drcb4y.jpg
    Analog > Camera feel optimization http://omeneo.com
    Digital > Camera performance optimization http://omeneo.com/primers
    imdb
    "Como delfines en el fondo del oceano
    volamos por el universo incentivados por la esperanza"
    "L'esperanza", Sven Väth
    "It's a poor sort of memory that only works backwards"
    Jung/ Carol
