Thread: small powerfull lights?
Page 1 of 3 123 LastLast
Results 1 to 10 of 22
  1. #1 small powerfull lights?
    Jul 2016
    Hello,
    Are there any new lights that pack a lot of power? The last lights I used were the aputure 300D LED's but shooting at harsh condition through softbox it wasnt nearly bright enough. So looking for something that packs a lot more light but that is still relative small but also affordable. I love the bowens s mount though. Does it exist?
    Thanks!
    Apr 2009
    SaltSpring Island, B.C. Canada
    So brighter than the 300d but small and cheap..... I think you can have 2 of those options but not 3.
    Senior Member Aaron Green's Avatar
    Jan 2016
    Chicago
    Is it even physically possible to make a 300w + LED in a body smaller than the 300d?
    Aaron Green - Chicago, IL
    DRAGON X
    www.instagram.com/aaronkgreen
    Mar 2011
    Houston TX (formerly Brooklyn NY)
    Might want to look into a k5600 joker. It's the only small light that can pack a good punch. If you have lots of cash burning a hole in your pocket, buy a new Joker 2. Or grab an older version 800.
    Jul 2016
    Quote Originally Posted by RobMNeilson View Post
    thx, 200,400 or 800w? Not sure how much a 200w joker bug brings to the table? (not possible for a bowens s mount on this right? probably also due to heat its not usable either)
    Senior Member Tim Morten's Avatar
    Apr 2008
    http://www.k5600.com/crossover/
    If you want to optimize for output in a small fixture, Jokers would be the way to go. Yes, they will get hot.
    Otherwise, Aputure 300D is probably the highest output small LED that I've found. Digital Sputniks are small and punchy, but I don't think they or the Hives have as much output. Rayzr is bigger and bulkier.
    Junior Member
    Nov 2013
    Sacramento, CA
    Check out the Profoto HMI's. I've got an old 1200W that still works just fine. The Profoto modifiers are world class and used by some of the best photographers out there.
    Mar 2011
    Personally I would only look into the joker 800. 400 is still useful, but you can sorta get there with a good LED. 200 is too small of a punch, but if someone wanted to give you one for free I'd take it!
    New York, NY
    Yeah joker is the way to go for brighter than 300w led in a small package. However hmi pars are pretty inefficient for diffusing due to the narrow native beam angle. If you're sure you want soft light you might get more out of a "mat" style LED light as they are even more efficient for diffusing than a cob. Perhaps you were losing a lot of light in the softbox.
    Noah Yuan-Vogel | noahyv.com
    Take a look at the Hive plasma fixtures. Not sure how small you need, but they-are-bright.
