Thread: 2019 RTX Laptops - Worth it?
Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
  1. #11
    Check out Clevo.tw
    Senior Member Ryan Sauve's Avatar
    Oct 2011
    Calgary, AB
    I actually just put in my order last night for a GIGABYTE AERO 15-X9-9RT4K5MP
    Specs
    OS: Windows 10 Pro
    Display: 15.6" 0.11 Inch Thin Bezel AUO UHD Adobe RGB 100% 3840x2160 IPS anti-glare display LCD
    CPU: Intel Core i9 8th Gen 8950HK (2.90 GHz)
    RAM: 32 GB DDR4
    Video: NVIDIA® GeForce RTX™ 2070 GDDR6 8GB
    Storage: 1 TB M.2 PCIe NVMe SSD
    IO: USB 3.1 Gen1 (Type-A) x 2
    USB 3.1 Gen2 (Type-A)
    Thunderbolt3(Type-C)
    mini-DP 1.4 & USB3.1(Type-C)
    HDMI2.0
    SD Card Reader(UHS-II)
    Weight: 4.4 lbs
    Price: $2,849
    Link: https://www.newegg.com/Product/Produ...-250-_-Product
    Convinced myself to downgrade and buy a Mavic 2 Pro with the difference. I can upgrade to 64GB of RAM later if I need it and only have to spend another $140ish to get a second NVMe m.2 SSD (500GB) under the hood to use as a scratch disk.
    Ryan Sauvé | @sauvedp
    Epic-W #7950
    Nikon Z6
    Aug 2007
    Texas
    Renewing this one since I'm shopping for a mobile workstation that can playback 8k at 1/2
    and do quick renders working off of TB/USB 3 external drives:
    Processor, how important? Older Intel good enough?
    RAM - How important? 16GB enough?
    GPU - All data I've seen based around gaming. For video rendering times, is 1080ti close in speed to any 20 series?
    Display - Gigabyte AERO has 4k "AMOLED" with 100% DCI-P3. Worthwhile vs the sRGB the other brands have?
    Thanks for any advice
    Robert Wynne
    AANASEA Media
    www.aanasea.com
    Oct 2011
    Calgary, AB
    Quote Originally Posted by Rob_Austin View Post
    So feedback regarding my specific machine mentioned above. I'd probably return it if I could and get something bigger with better air flow but I guess it'll do for now. The reason is thermal throttling. It can't handle the heat so the CPU has to throttle big time when rendering. As for playback, it can do 8K 12:1 at 1/4 smoothly but starts to struggle at 1/2. I'm okay with that since I edit on a 1080p monitor.
    Epic-W #7950
    Nikon Z6
    Dec 2010
    Toronto & Vancouver
    Quote Originally Posted by Ryan Sauve View Post
    How about in RCXp with GPU debayer enabled? I was under the impression that something like an 8GB RTX could 8k full res at 24p+?
    Aug 2007
    Texas
    I'm reading that you'll need at least a full 2070, 2080 (not the Max-Q version) or a newer Quadro 5000+ to get close to that
    I'm wondering if playback times correspond closely with render times.
    I'm debating a 2060 vs a 2080. Some of the thin 2060 laptops under $3,000 have a 4k screen with 100% P3
    VS.
    similar price full 2080 workstations that have lousy screens not good for color work.
    Robert Wynne
    AANASEA Media
    www.aanasea.com
    Aug 2007
    Texas
    Would anyone else recommend buying from HIDevolution or Pro-Star?
    I found an EVOC model with good specs for good price. Thanks
    Robert Wynne
    AANASEA Media
    www.aanasea.com
    I have friends using the oled uhh razor and they are very happy with it.
    Björn Benckert
    +46855524900 www.syndicate.se/axis
    VFX / Flame / Motion capture / Monstro
