Thread: Zhiyun Crane 2 working with Raven
Results 1 to 9 of 9
  1. #1 Zhiyun Crane 2 working with Raven
    Apr 2014
    Greater Portland
    For anyone curious, I was able to mount my Raven body, w/VLOCK IO, 4.7" LCD, and pancake 24mm Canon lens on the Zhiyun Crane 2 gimbal with success. I ended up getting a dummy VLOCK plate and strapped it to the dual handlebar. That let me mount the battery on the handlebars, and run a coiled DTAP to DSMC (angled) connector to the Raven for power. I did have to use a longer'ish (is that a word?) Manfrotto plate so that I could slide the Raven far enough forward on the Crane mount. After turning the motor strength up to the highest setting, it was working pretty well. Sure, it's not a Movi Pro... but I can't strap a Movi Pro to my backpack, either. :)
    Senior Member Kwan Khan's Avatar
    Jan 2008
    NYC
    Ronin S as well but not my favorite setup.
    No, I do not RENT MY GEARS... - NYC (Times Square)
    EPIC-D with 9" touch, 4 RAVENs, RPP, Sigma 18-35 PL, Motion Mount, VF/RED-rock wireless FF, Pana 17", JVC 20", Seadicam with SEGWAY, Letus 4-Axis with L'Aigle Exoskeleton.
    Trash-Can 12-core Max'd-out) +MBP (Retina), RED Rocket (Sonnet), RAID system (Promise Pegasus II), Adobe Production (CC), FCS2, Resolve 12 with MC Color, 50" 4K Panel
    Apr 2014
    Greater Portland
    Hey Kwan, that setup seems like a good configuration, and the wiring tips are great.
    I opted for a setup that kept the 4.7" on the camera body itself, which let me switch everything between the gimbal and a tripod very quickly... like within a minute. However, my setup does not include a follow focus, so I'm limited to the "stay in the same range from the subject" filming method.
    And I'd agree that the Ronin S and/or Zhiyun Crane 2 are not the "best" setup, but pretty mobile, and quite affordable.
    Senior Member Tim Morten's Avatar
    Apr 2008
    I'll be interested to see how the Moza Air X pans out... 6kg payload is on par with the ACS Beast. The handle configuration is questionable, but I don't want to pre-judge before it's in the wild.
    Jan 2008
    NYC
    Quote Originally Posted by Kevin D'Haeze View Post
    Agreed, the reason I said is "not my favorite setup" because I built that with the only available accessories we have. Not planing to buy any specific accessories just for Ronin S since there will be Ronin T, U, V, W, X, Y, and Z so on every month (lol).
    Apr 2014
    Greater Portland
    Kwan, do you use a REC trigger button? I'd like to mount one to the handlebar grip so that I can start/stop without touching the cam. I've seen a few around the market, but no good reviews.
    Jan 2008
    NYC
    Yes, I use Tilta DSMC2 Run/Stop Cable (connect Handgrip to Raven)
    Junior Member
    Jul 2016
    Portland, OR
    Hi Kevin, Curious *what Dtap to Lemo cable did you use? I found one the DJI Ronin-M Power Cable for RED DSMC Cameras, but wasn't sure if you'd recommend a different one.
    I have seen other cables that are Dtap to 4-pin Lemo, but I'm not sure if they are all the same when it comes to 4-pin Lemo or if there is special circuitry for a RED specific Lemo.
    Thanks -George
    Apr 2014
    Greater Portland
    Hey George, I got one from eBay and it works great... seems well-made.
    https://www.ebay.com/itm/Red-Scarlet...72.m2749.l2649
