Click here to go to the first RED TEAM post in this thread.   Thread: Announcing the RED DSMC2 PRODUCTION MODULE
Page 3 of 10 FirstFirst 1234567 ... LastLast
Results 21 to 30 of 97
  1. #21
    Just a note and thought. On the product page it states only one module could be used with this new Production Module. But I'm nearly certain I spotted Jarred sporting the Teradek DSMC2 Bolt in front of this thing. Am I crazy?
    Also, just to ask, any upgrade path from the previous REDVOLT Expander?
    phfx.com IMDB
    PHFX | tools
    Data Sheets and Notes:
    Red Weapon/DSMC2
    Red Dragon
    Senior Member Ketch Rossi's Avatar
    Jan 2007
    ITALY | USA
    Yeah that is what Jarred said, and going that route too, so wondering of those few holes on top of the new Production Top plate will allow for the Teradek DSMC2 Bolt to pass trough :)
    Love that new plate :)
    F I L M M A K E R
    ____________________
    LOVE IT!!! the new top handle is so so bad ass. Can we get some news on the High Bright Monitor? :-)
    Jacob Schwarz
    Director / DP
    www.jacobschwarz.net
    Monstro 8K (Storm) 33 / Forged Helium 8K #29 / Epic-W
    Follow Me: Twitter / YouTube
  4.   Click here to go to the next RED TEAM post in this thread.
  #24
    REDUSER.NET Brent Carter's Avatar
    Aug 2007
    Irvine CA
    Fair enough. It was meant as "no other RED expanders/modules" can be used with it. Like, no separate battery plate and module. I am having it deleted, does not add a ton of value.
    Not at this time, no.
    Senior Member mikeburton's Avatar
    Sep 2007
    Sacramento CA
    Are there built in pre-amps in this unit? Did I miss that somewhere?
    Senior Member Brian F Kobylarz's Avatar
    Dec 2007
    Norwich, CT. USA
    I would like to hear about the pre-amps too.
    Has there been any testing to determine WiFi performance (thinking FoolControl) with the added metal and no antenna jumper?
    Quote Originally Posted by Brent@RED View Post
    ……..The secondary LCD/EVF port and an HDMI/MON-1 port cannot be used at the same time.
    So are you saying that I cannot run both an EVF and Touchscreen at the same time?
    Right now, using the WC Top Plate to accomplish this.
    Spoiled by being able to use both simultaneously.
    Using the TS for setup and client ots or ca monitor on a Noga/CineLock while I use the EVF for concentration...
    From examining the picture, should I have any concerns that the LEMO Power Outs might end up impacting an installed side handle?
    Fair enough. It was meant as "no other RED expanders/modules" can be used with it. Like, no separate battery plate and module..
    First, I guess this means my AB ET Battery plate goes away.
    I’ll miss the dragon scales.
    How I wish the AB version was out of the gate this year…
    Finally, to remove any confusion, if you are using the package listed above (with new top plate & handle), the Teradek DSMC2 module is in or out?
    Mar 2017
    Orlando, FL
    I'd also like to hear about the pre-amps as well as the ability to run it with the Teradek DSMC2 module!
    RED DSMC2 GEMINI #011030
    Jan 2007
    ITALY | USA
    Quote Originally Posted by Brian F Kobylarz View Post
    If it doesn't work Mark confirmed that Teradek will be also making a Top plate solution, which will allow the Top Handle and DSMC2 Bolt, and or also the new ACI sidekick.
    Or we could just drill couple of holes on RED's Production Top Plate to poke the Antennas out of ;)
    F I L M M A K E R
    Junior Member
    Feb 2014
    Love this but it misses the mark for lightweight set-ups. You guys cooking up anything for the solo ops? single xlr with a single row of ports... :)
    So am I correct if I say this module:
    -clones the normal sdi out.
    -gives an extra sdi option, that takes the evf/hdmi.
    So not possible to feed three sdi outs without loosing evf?
    Björn Benckert
    +46855524900 www.syndicate.se
    Flame / VFX / Motion capture / Monstro
