Thread: KipperTie Revolva EF major image quality issues (softness + chromatic aberration)
Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
  1. #11
    Junior Member
    Aug 2017
    Hi Elias,
    I had the same issue, but found out you have to remove the black lens flare protector that's located on the OLPF. I'm guessing you took the OLPF out cause it wouldn't fit? It will once you remove the inside edge seal.
    Senior Member AndreasOberg's Avatar
    Oct 2011
    Yes you have to remove the protector.
    I did tests outside and could not see any degradation at all. The image looked completely identical, colors were perfect. Sounds strange that it would cause chromatic abberation.
    Did you ever figure out what was the problem?
    Andreas
    www.ObergWildlife.com- Natural History Filmmaking
    www.WildlifeRescueMovie.com- Saving the animals of the Rainforest!
    2 x RED DSCM2 8K Helium, Phantom 4K VEO990, Movi Pro Gimbal, Inspire 2 X7, OConnor 2560, Canon 50-1000mm
    Senior Member jake southard's Avatar
    Apr 2014
    Santa Monica, CA
    I was having some VERY strange/horrible lens flares last week when I used my Revolva PL mount for the first time with angenieux EZ lenses. When pointing towards/at lights ( NBA arena lights in this case) there were red colored ghost flare dots everywhere. not sure the correct term for this, or if this is normal. But when pointing towards other lights as well, there was noticeable bleeding at the top of the frame. Was using 0 ND and .6
    RED Gemini
    Alexa Mini - SOLD
    Epic Dragon - SOLD
    Scarlet Dragon - SOLD
    Scarlet MX - SOLD
    RED One MX - SOLD
    DP // Director
    www.jakesouthardcinema.com
    https://vimeo.com/jakesouthardcinema/videos
    Senior Member John Marchant's Avatar
    May 2010
    Normandy, England
    Important to note that this thread relates to a long-resolved issue from the first couple of months of manufacture. Not something that is a concern right now or for the last couple of years.
    Gate flare from the edge of frame is something we can potentially address for you if you send us an email. We updated some small design elements incrementally through production, and depending on when your mount was bought you may be eligible for a free component to help mitigate gate flare.
    Red dot pattern however sounds like the usual sensor vs f-stop issue, resolved with higher ND value and a larger aperture. Not a a revolva specific issue.
    KipperTie - Authorised RED Rental, Pinewood Studios, UK
    Ready to hire: Monstro 8K VV | Gemini 5K | Helium Monochrome 8K
    Check out our Revolva ND solution, OLPFs and other products
    Nov 2011
    Brooklyn
    Quote Originally Posted by John Marchant View Post
    Was gunna say same thing - red dots sound like sensor reflection, a common problem on all cameras at certain F stops.
    Nick Morrison
    Founder, Director & Lead Creative
    // SMALL GIANT //
    smallgiant.tv
Tags for this Thread
View Tag Cloud
