Click here to go to the first RED TEAM post in this thread.   Thread: Which monitor will you use for RED post production?
Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 32
  1. #11
    Seems like the multibridge extreme and an apple 30" would be great for true 2K but based on what you said, Mike, it seems that the color would not be trusted and I would need another production monitor for color? What about using eye-one or some other calibrator--will that help?
    An awful lot of money between the multibridge extreme and a 30" for to only turn around and spend another 3-5K$ on a monitor for color. Is there anyone with a better solution than one monitor for pixels, one for color?
    Maybe if we all pray that apple releases a new 30" Cinema Display Pro with better features, deeper blacks, and professional controls!
    Banned
    Apple 30 for pixels, Eizo 24 for color with a EyeOne probe (both for under $2k).... The Eizos come with their own calibration software.
    Banned
    I talked to a friend that does engineering over at ILM and she said to look into the Eizo monitor. This seems to be a no brainer for post work. The tough decision is finding a monitor that I can have on set and use at home without having to re-calibrate. Resolution is what we'll be looking for most on set considering raw data monitoring wont be color accurate. Maybe they'll have a 2k option that's also rugged come camera delivery time. We have to remember that any monitor that's being lugged onto set has to be able to take it.
    I was also wondering what it would take to apply a preset LUT to a monitor output. Can you do that in camera or do you need a separate system?
    Thanks ffor the tip _BK.
    Senior Member Joe Carney's Avatar
    Northern VA
    Quote Originally Posted by Appleton View Post
    I'm thinking of using a 1080p projector - possibly the Sony VW1000. It uses 3 chips, projects at 1080p, has a 15000-1 (they claim) contrast ratio.
    Shoot 4K -> convert to 1080p, edit, preview, and possibly finish...
    It's a brave new world, indeed.
    Check out the Sony vpl-vw50, half the price, same quality.
    Joe C.
    Banned
    tonaci, that monitor is for print use and is a LOT more expensive because it can produce the full Adobe RGB colorspace. The bad thing about it for video post is its very slow refresh rate ~30ms. The CE240W is what I am using, and although it still has a bit slower refresh rate than other professional video post monitors (~8ms), the color accuracy cant be beat.
    Senior Member Nick Shaw's Avatar
    London, UK
    I currently have a Panasonic 17" BT-H1700P which I will use for colour critical work, and two 23" Apple Cinema Displays which I will use to see detail. Pretty similar to Mike Curtis' setup. I currently have a G5 and Decklink HD Pro, but realise I will need to upgrade to an Intel (8 core by then?) to run REDCINE. I'll probably get a Kona 3 to go with that, unless AJA or Blackmagic come up with anything better in the mean time. The Kona 3 can currently show a realtime 1080p window on a 2K FCP timeline. Who knows, by the time Red ships maybe it will be able to show a 1080p output (half scale and windowed) from a REDCODE 4K timeline, or maybe there will be a Kona 4(K) which will do so. I'm sure Ted is talking to his contacts at AJA about this kind of stuff.
    Nick
    Color calibration should be most important once you determined what your final outputs will be. For most I would guess a really good HD reference monitor would be enough for HD-DVD or Blu-Ray
    For those who want a D-Cinema or Film output, that gets more complicated unless you plan to use a good post house.
    Rumor mills suggest an Apple 50" may be coming down the pipeline...
    Quote Originally Posted by penfever View Post
    only to tie in with iTV to compete with plasma/lcd tv's I heard.. Apple want to be everywhere you live/eat/sleep/drive etc...
    don't think it will be 4k
