Thread: Resolve Export Settings
Page 1 of 2 12 LastLast
Results 1 to 10 of 13
  1. #1 Resolve Project Settings and Export Settings
    Just curious what the recommended project settings and export settings are for RED footage in Resolve?
    (Screenshots would be helpful)
    Sterling Williams
    @sterling.a.williams
    RED Scarlet-W
    www.sterlingandrewwilliams.com
    Aug 2011
    Sterling,
    These are the settings I use Personally, However others may have something different.
    1)
    2)
    3)
    Just "Raw Profile", "Decode Quality" and "Bit Depth"
    Senior Member Akin A's Avatar
    May 2014
    NYC
    Rand, do you get compression artifacts when exporting 4K H.264?
    I always get 4K H.264 artifacts in Resolve 14 and 15b. 2K H.264 is clean for me though.
    I've even tried to first export R3D to DNxHR (no artifacts) and then to 4K H.264, as some suggested in the Resolve Facebook Group, but it still gives artifacts after being transcoded to H.264.
    For YouTube, I usually export 4K DNxHR and everything is clean, so there are no problems.
    For Facebook, for 4K, I'm stuck at the moment because Facebook doesn't currently accept DNxHR. I'm on Windows, so I can't export ProRes.
    Filmmaker, Actor
    Website | Facebook | Instagram | Twitter | YouTube
    Epic-X Dragon #08468 | Sigma Art 35/1.4, 50/1.4, Rokinon 85/1.4
    Aug 2011
    Akin,
    I always use a very high bit rate to try to help negate that somewhat. Before my last Mac died, I exported the project out as ProRes 422HQ. However, since I switched back to PC, I have been just using H.264 at really high bit rates. I'm still trying other output codecs, but some are simply not compatible with Youtube or Vimeo.
    May 2018
    Chicago, Illinois
    I don't upload to YouTube so I am not familiar with the artifacting. What are some of the concerns there?
    I know YouTube handles 50Mbps files with no issues -- do you actually see artifacts when uploading at 50Mbps?
    Scarlet-W
    Senior Member Antony Newman's Avatar
    Mar 2012
    London, UK.
    Not sure if this pipeline would help others:
    +) As H.265 creates smaller files than H.264 for the same quality / has fewer artifacts (that I am aware of).
    +) And FCPX can work in parallel creating H.265 on the same machine with Resolve working on something else.
    My workflow was :
    1) Export in a high quality from Resolve (Prores 4444 XQ) (Pretty quick)
    2) Open file with FCPx (Compressor) -> Export as H.265 (Quite slow) : For uploading to Vimeo
    3) Open file with FCPx (Compressor) -> Export as 4k Apple Device (Pretty quick) : For a local copy on an iPad
    As soon as (1) is complete you can continue project work in Resolve.
    4) SIDE NOTE : As there a previously a bug in MONSTRO exports in Davinci -> I have sometimes had to import the output into FCP-X and manual fix the corrupted frames. BM never stated the cause (and I have not seen it specifically fixed) - however - I did note (if Peter Chamerbin is reading) that RED themselves has a fix for this 'sort of anomaly' in a recent R3D framework patch.
    AJ
    Updated to now include suggested project settings as well. So hopefully there are start to finish instructions.
    Sterling Williams
    RED Scarlet-W
    bump
    Sterling Williams
    RED Scarlet-W
    Come on guys. 362 views and yet only 2 people have given feedback with their recommended settings. BUMP!
    Sterling Williams
    RED Scarlet-W
    Jun 2017
    Quote Originally Posted by Sterling Williams View Post
    Not many argue with Rand when it comes to Davinci Resolve.
Tags for this Thread
View Tag Cloud
