Thread: Call for better audio recording on newer RED cameras.
Page 10 of 10 FirstFirst ... 678910
Results 91 to 99 of 99
  1. #91
    Junior Member
    May 2007
    Atlanta
    My solution is a Ranger Gemini. Thankfully the new Rangers are purchasable and have a 5 pin xlr with Phantom power and hi/mic switch. I have ordered my camera but have not yet received it. I look forward to testing the audio.
    Pat Cooksey
    Director of Photography
    Motion Visual Productions, LLC - Kennesaw, GA
    www.motionvisuals.com
    Kit: Red Ranger Gemini Package
    DSMC2 Red EVF
    7" Monitor
    Lots of other stuff
    Senior Member Patrick Tresch's Avatar
    Aug 2007
    Switzerland, Lausanne
    Small Recorder is an Iphone8 ;-)
    Self powered stereo preamp with +48v by Sonosax
    You can also use a Weapon (or any DSLR) as recorder.
    Aug 2007
    And here on my Weapon MG
    Sounds really good. The preamp has a Mixer menu where you can put a limiter. I put mine at -12db and the gain mic at +35db. So it puts the 132db of DR of the preamp to a more usable DR for the analog Minijack input of the camera and won't ever overload it.
    Here is an audio clip form the R3D.
    MS CCM41_CCM8 Schoeps
    M2D2 limiter set to -10db in the Mixer menu and audio gain at +35db
    Unballanced stereo out (TA3) from the M2D2 to minijack input of the camera set to 0dB gain.
    NJ
    Quote Originally Posted by Patrick Tresch View Post
    It seems like a decent setup for what on board RED audio can currently support.
    Would like to see hardware like that mixer built into the camera (or added through a module)
    and across 4 separate XLR inputs. RED has come reasonably close in the past (RED ONE) and
    I think they can do it again.
    Brian Timmons
    BRITIM/MEDIA
    Oct 2014
    Auckland, New Zealand
    Quote Originally Posted by Brian Timmons View Post
    Canon and Sony supports 4 XLR channels in their latest mid range cinema cameras.
    C500 Mkii
    https://www.usa.canon.com/internet/p...s-c500-mark-ii
    FX9
    https://pro.sony/en_GB/products/hand...sBlock-pxw-fx9
    Naturally, I hope RED takes notice and acts.
    While I highly doubt RED Komodo will support anything like 4 channels, it would be nice if integration (i.e trigger record) with a recorder like the Zoom F6 can be made.
    https://zoom-na.com/products/field-v...field-recorder
    Brian Timmons
    BRITIM/MEDIA
    Even their old FS7 mk1 still allowed 4x XLR inputs via the smart shoe accessory.
    http://IronFilm.co.nz/Sound/ (Sound Recordist based in Auckland, NZ. Happy to travel too)
    https://www.youtube.com/c/SoundSpeeding
    Junior Member
    May 2007
    Atlanta
    I have been working with the audio on my new Ranger Gemini. It’s great but a headphone and gain knob would be nice. I am using a Shure FP33 mixer with an imbilical cable with return audio for monitoring. It works great with the Ranger. I also have a Zoom F4 recorder with timecode and RTN audio which also works to go simultaneously direct into camera as well as 4 discrete channels of separate double system sound. It behaves as a mixer close to the FP33 except the stereo line output is at a lower level than most pro line level signals with no way to adjust it. I’m still working with settings inside the Ranger to optimize the system.
    Pat Cooksey
    DSMC2 Red EVF
    7" Monitor
    Lots of other stuff
    Oct 2014
    Quote Originally Posted by Pat Cooksey View Post
    Actually the Zoom F4 is a 6 channel / 8 track field recorder.
    Senior Member Blair Thornton's Avatar
    Oct 2013
    Toronto
    Patrick, where did you find those colourful TA3-F cables?
    Oct 2014
    Quote Originally Posted by Blair Thornton View Post
    Seen those before, but I can't recall what brand they are.
    But I know Cable Techniques for instance makes color coded low profile TA3F connectors / cables.
    Anyway, just ask any of your local pro location sound stores and they can either make whatever custom cables you want or point you to someone who can.
