Thread: RED Epic-W Soft Focus Issue
Page 1 of 3 123 LastLast
Results 1 to 10 of 22
  1. #1 RED Epic-W Soft Focus Issue
    Member Randy Kessler's Avatar
    Apr 2016
    Farmington, CT
    Hello Everyone,
    I have noticed on my Epic-W while shooting, my video has been hard to focus in on and I am getting soft images, making it hard to get a sharp focus point. I primarily see this issue when using the Canon II EF f/2.8 70-200mm lens. This problem usually persists later on while the camera has been on for a while and filming. When I am filming the start of a football game the focusing is pinpoint accurate. Later on in the game I start having focusing issues (right after halftime) and the image begins to become very soft. (I will post picture link below). Would this be a back focus issue maybe? Any help would be appreciated! Thanks!
    https://www.flickr.com/photos/731723...57689892666485
    Last edited by Randy Kessler; 11-21-2017 at 10:37 AM. Reason: images won't come up
    Raven XXXX - "BUBBA"
    Senior Member Tom Dowler's Avatar
    Dec 2015
    Los Angeles, CA
    Do you also have a shot of what it's like at the beginning of the game, for comparison?
    This, to me, looks like fogging - some kind of condensation on the lens, maybe?
    Are you able to reproduce with the same lens on a different camera? Whatabout another lens on the Epic?
    Anglo-American DP, shooting docs and branded content in LA.
    tomdowler.com
    longhaulfilms.com
    lettinggoofadele.com
    restartingthemotorcity.com
    That looks rather uncharacteristic of this lens and camera combo. Are you using any filters? Is it very humid or moist out? Almost looks like condensation build up.
    I only ask as I see halation that's inconsistent which is revealed further if something is out of focus.
    phfx.com IMDB
    PHFX | tools
    Data Sheets and Notes:
    Red Weapon/DSMC2
    Red Dragon
    Senior Member Jacek Zakowicz's Avatar
    Jun 2008
    I would say definitely a problem with your lens. Seems like a major glass misalignment. This is not a back focus/flange depth issue IMO. Maybe the lens is not mounted correctly?
    Maybe you can swap it on a canon body and take a picture? that would explain a lot...
    Jacek Zakowicz, Optitek-dot-org, jacek2@optitek.org
    Professional Broadcast and Digital Cinema Equipment
    Apr 2016
    Farmington, CT
    Thanks for responding guys. Yeah this really happens in the coldest of weather. The air seems pretty dry but still the cool air can probably bring some condensation into the lens. It seems that the fogging only happens with the 70-200mm lens. I put some new images on that Flick link if you want to check it out. Thanks again for responding.
    Jun 2008
    Condensation usually sets when the lens is moved from warm to cold . Most of the time in the morning. just look into the lens- easy to see....
    Senior Member Christopher S Johnson's Avatar
    May 2017
    Los Angeles, CA
    Quote Originally Posted by Jacek Zakowicz View Post
    Did you go inside during halftime? I love a good camera mystery solving!
    Apr 2016
    Farmington, CT
    Quote Originally Posted by Christopher S Johnson View Post
    Christopher, I did not go inside at all. Camera and lens just stayed on the tripod, in the elements.
    Dec 2015
    Los Angeles, CA
    I once dropped a cheaper Canon lens and got halation like this. I think it was from elements being misaligned.
    any chance there was a physical knock to it?
    tomdowler.com
    longhaulfilms.com
    Apr 2016
    Farmington, CT
    Tom,
    This lens has had no damage to it. I've also used my other 70-200mm with the Epic-W and the same thing happens.
